I run latest version of HA via docker on a Synology NAS and want to add MQTT broker but I’m missing the add-on section …
Any ideas how to enable it ?
Can you share what it says in the system health section in info (settings → info from the menu you’re looking at)?
HA on Synology NAS does not support Add-On (what I know)
Isn’t that menu a part of the HA Supervised install, not the base Docker?
Grab the full HA OS VMware download, and run it under VMM on the Synology. Works fine on my DS-918+ and all options are present…
I face the same running HA in a docker container. How can I use addons?
My answer above still applies. Here’s the grid that explains what is included in each install option:
https://www.home-assistant.io/installation/#compare-installation-methods
