Hi, I’ve recently managed to break my HA SmartThings integration after replacing my BT Smart Hub 2, due to its inability to actually reserve ip addresses. I changed my IP address range and as a result my Smartthings integration broke. I reinstalled it but it found no devices instead of the 100+ that should be there.
As a result I decided to totally rebuild and start again. I’ve refreshed an SD card and started from scratch, and the new instance has immediately linked to my Hue Bridge, but I’ve noticed that my configuration page is missing my cloud option so that I can reconfigure my Nabu Casa account, which I believe I need to re-setup my Smartthings integration.
I’ve searched for the correct thing to enable it, and added the line ‘cloud:’ to my configuration.yaml, but with no success. I do have
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
at the top of my configuration.yaml, so tried commenting that out, and promptly broke all the other bits I was expecting to see, so it’s back in and now I’m a bit stuck…
Jules
