i just installed my hass.io latest version, and installed the configurator, but i don’t see it in the left menù. Searching on internet/forum i found that i need to add hassio: in the configuration.yaml and restart, but the configurator is still missing… any error in the log…
my configuration.yaml is the following:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 000000000000
longitude: 000000000000
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Rome
# Customization file
customize: !include customize.yaml
packages: !include_dir_named packages
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Show the introduction message on startup.
#introduction:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
#http:
# base_url: example.duckdns.org:8123
# Discover some devices automatically
discovery:
# Sensors
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
hassio:
group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yaml
if i navigate to http://<hassio_ip>:3218 i get a connection refused, while if i open the configuration from the “open web ui” in the add-on page i can open it successfully
