Missing controls toggle button on all new devices
I have HA 2023.6.3 running on a RPi4. I use Aeotec Z-stick 7 fw:7.17.2 with 25 devices.
It’s been a few months since I added a new z-wave device, but now any z-wave device I add is missing the controls toggle button and configuration and diagnostic is all greyed out.
I have tried adding 3 different devices, the last one being one that was working perfectly, that I excluded and included again (and now missing the toggle)
Any ideas what went wrong?
Have you tried restarting HA (a few times maybe)?
I know that’s fixed some strangeness after installing new devices for me in the past.
Thanks for the comment, I have restarted quite a few times trying to troubleshoot without success.
Have you tried re-interviewing the device? That will force the Zwave-JS driver to get the device ID and re-load the device configuration file. If that doesn’t work, then that means either it can’t get the device ID (problem communicating between Zwave-Stick-Device) or it doesn’t know about the device (possibly a corrupt ZwaveJS installation?)
If you can check the log during the interview, it might give you a hint as to where the problem is.
-David
