Missing Database File
where can I find my database file home-assistant_v2.db? As you can see on the attached screenshot, it is not in the standard folder. How can I find out where it is?
2022-11-13 11_25_29-Studio Code Server – Home Assistant
Okay, it was my own fault. I was using the Studio Code Server Add-On as the file explorer, and that will not show me the *.db-files. When using the File Editor Addon, the data base is at its estimated location
