Hi all,
I recently connected an Aqara D1 wall switch via zha. Its a 1 button zigbee switch with neutral variant. Using zha, I’m able to listen to state change events on the switch when the button is pressed.
I’m not able to find zha_event. Only state change events are emitted when the button is pressed. Is there a way to get double click events from this switch?
I have a no neutral 1 button version and that emits double click events correctly via zha_events.
Does anyone have experience setting up this switch? I see posts about using zha quirks but I’m not sure if my device is setup correctly to retrieve zha_events with double click.
