Sorry, no idea what that is doing, if the CT clamp platform is output in Amps, multiply it by your voltage to get Watts
have a look here, someone else has done it, the 230 is the voltage
If I remember, I found this info online and followed it. The result is what you see.
So does any one have any idea as to what it should look like. I find following the info in ESPhome works on the assumption you have the knowledge, but need a little help. Plus Im not good at programming.
I can follow someone’s else’s file and learn from it…
Something like this, you’ll need to do the calibration and set the voltage to match yours
Change the update interval to 60s once working
- platform: adc
pin: A0
- platform: ct_clamp
sensor: adc_sensor
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
- 0.12 -> 17.4
- lambda: return x * 230.0;
unit_of_measurement: W
- platform: total_daily_energy
name: Total Daily Energy
power_id: measured_power
filters:
- multiply: 0.001
unit_of_measurement: kWh
accuracy_decimals: 3
icon: mdi:clock-alert
device_class: energy
Thank you very very much for all your help.
I will change the yaml file over and see what happens.
Cheers
Still can’t get the energy option to pick up my CT Clamp. I have made the changes, but still does not appear.
name: “Total Daily Usage”
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 1
accuracy_decimals: 2
state_class: measurement
time:
- platform: sntp
The only thing I read is to do with last_reset but you get an error if you add it???
The only thing the new energy option pick is a power option on a blind motor.
friendly_name: Dining Blind Motor Power Meter
device_class: power
Which has no data on it any way, so big time confused. I do wish the documentation for this could be clearer and full explained in ESPhome.
Thanks for any help…
How come you have - multiply: 1
instead of - multiply: 0.001
Show us your full config
This is the full yaml:
platform: adc
pin: A0
platform: ct_clamp
sensor: adc_sensor
update_interval: 10s
filters:- calibrate_polynomial:
degree: 1
datapoints:Map 0.0 (from sensor) to 0.0 (true value)
- 0.0 → 0.0
- 0.01 → 0.008
- 0.020 → 0.018
- 0.025 → 0.023
- 0.04 → 0.037
- 0.08 → 0.07
- 0.11 → 0.10
- 0.12 → 0.13
- 0.14 → 0.15
- 0.20 → 0.21
- 0.34 → 0.39
- 0.40 → 0.46
- 0.60 → 0.68
- 0.80 → 0.88
- lambda: return x * 23.0;
unit_of_measurement: “Kw”
filters:
- multiply: 1
time:
- platform: sntp
I have changed the multiplier to get Kw not Watts and the only way to get the kWh to work is the multiple by 1. I cant see that this would be the reason why it does not appear in the device list in energy. But if Im wrong then please say.
Cheers
Thanks to all for help and support. I have managed to get it to appear in energy management, by adding the missing info through Customizations option.
Just have to work on changing the charts…
