Hi, I have a working home assistant configuration with several devices, mainly thermostats (like Tuya Smart Home ZigBee TRV Thermostat Radiator Valve Actuator Programmable Temperature Controller Support Alexa Google Assistant|Building Automation| - AliExpress and Tuya ZigBee3.0 Smart Radiator Actuator Programmable Thermostatic Radiator Valve Temperature Controller Voice Control via Alexa|Building Automation| - AliExpress) and thermometers. Plus the zigbee gateway which is a Sonoff Bridge Gateway which I patched with Tasmota.
Now since a valve’s got broken, I bought another one (Termostato ZigBee valvola attuatore radiatore Tuya regolatore di temperatura TRV programmabile intelligente Alexa Voice Control|Building Automation| - AliExpress) which works perfectly with SmartLife client which I connnected it initially using its gateway to check possible updates, however when I try to connect it through the tasmota bridge configured in my home assistant, it gets recognized as this " _TZE200_a4bpgplm TS0601" device:
It seems it doesn’t have any entities associated. But it also seems to me that it’s not even recognized as a thermostat, is it?
Any help, really appreciated. Thanks
