Debuging my own issue:
- mqtt.debug shows well messages when the “setpoint” is changed on my device (manually), so Home Assistant well receive events but it does not want to add the matching entitiy
OpenZWave/1/node/20/instance/1/commandclass/67/value/281475317547026/,{ "Label": "Heating 1", "Value": 20.0, "Units": "C", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Decimal", "Instance": 1, "CommandClass": "COMMAND_CLASS_THERMOSTAT_SETPOINT", "Index": 1, "Node": 20, "Genre": "User", "Help": "Set the Thermostat Setpoint Heating 1", "ValueIDKey": 281475317547026, "ReadOnly": false, "WriteOnly": false, "Event": "valueRefreshed", "TimeStamp": 1601716245}
OpenZWave/1/node/20/instance/1/commandclass/67/value/281475317547026/,{ "Label": "Heating 1", "Value": 22.0, "Units": "C", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Decimal", "Instance": 1, "CommandClass": "COMMAND_CLASS_THERMOSTAT_SETPOINT", "Index": 1, "Node": 20, "Genre": "User", "Help": "Set the Thermostat Setpoint Heating 1", "ValueIDKey": 281475317547026, "ReadOnly": false, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1601716246}
OpenZWave/1/node/20/instance/1/commandclass/67/value/281475317547026/,{ "Label": "Heating 1", "Value": 22.0, "Units": "C", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Decimal", "Instance": 1, "CommandClass": "COMMAND_CLASS_THERMOSTAT_SETPOINT", "Index": 1, "Node": 20, "Genre": "User", "Help": "Set the Thermostat Setpoint Heating 1", "ValueIDKey": 281475317547026, "ReadOnly": false, "WriteOnly": false, "Event": "valueRefreshed", "TimeStamp": 1601716246}
OpenZWave/1/node/20/instance/1/commandclass/67/value/281475317547026/,{ "Label": "Heating 1", "Value": 20.0, "Units": "C", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Decimal", "Instance": 1, "CommandClass": "COMMAND_CLASS_THERMOSTAT_SETPOINT", "Index": 1, "Node": 20, "Genre": "User", "Help": "Set the Thermostat Setpoint Heating 1", "ValueIDKey": 281475317547026, "ReadOnly": false, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1601716249}
OpenZWave/1/node/20/instance/1/commandclass/67/value/281475317547026/,{ "Label": "Heating 1", "Value": 20.0, "Units": "C", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Decimal", "Instance": 1, "CommandClass": "COMMAND_CLASS_THERMOSTAT_SETPOINT", "Index": 1, "Node": 20, "Genre": "User", "Help": "Set the Thermostat Setpoint Heating 1", "ValueIDKey": 281475317547026, "ReadOnly": false, "WriteOnly": false, "Event": "valueRefreshed", "TimeStamp": 1601716249}
Setpoint (temperature) set to 22 degres, then back to 20 degres from the device.
So why home assistant ignores it and have not the entity in front?
