Missing graph bar with error on mobile app only
Hello, I have been using homeassistant for half a year. Up until now there have been problems after updates that have been resolved.
But since the last update I can no longer see my energy view
that I made with - type: custom:bar-card.
However, if I view it via the web browser then it works. It seems to be a problem with the app.
Do you know how to fix it? Thanks in advance and all the best
I push them up, when will the problem with the android app fixed or is it notet?
Thank you
Good morning,
What have you done in developing with the mobile app!!!
Since the last update custom graph bars are not displayed and since today the cusom power distribution card.
At start ist shows after view seconds the Error Message wil show card not found.
Can you check this ir does other have tge problem to?
Gby
I only can put one pic in the post
The second here
Gby
The mobile apps only officially support core cards. If you are having issues with custom cards you should raise an issue with the custom card developer(s) on github.
e.g. Issues · custom-cards/bar-card · GitHub
and Issues · JonahKr/power-distribution-card · GitHub
The bar chart card in particular has not been updated for 5 years and could be considered abandoned. You should probably look for a maintained alternative.
Neither repository has an issue about Android specifically. It coud just be an issue with your particular setup.
Hi
It has work, until the update.
And now its my fail?
I wars a good project, able to handle for not “nerds” but now?
What is to do for working again?
And why ist it working on http view? And how long will this work on http browsing? Until this will pacht down to not working?
Sorry but i have done 1 year of work to get them run and one update maks them to unuseable!
Have i set on the wrong horse?
Sorry im a sad but i m not coder not it or computernerd
Simply because no one else has reported this occurring. You may be the first to notice it but that is unlikely considering when it was released.
Already told you:
Unfortunately that is the nature of custom integrations and cards. Some get abandoned. If you want a reliable supported system, stick to core cards or at least developers of custom resources that have a track record of supporting their projects long term.
Sorry im think you dont read all
In tlhe Browser it works whell
ONLY THE ANDROID APP IS NOT RIGHT DISPLAY
Why did you mark my post as the solution then?
Did you open the issues with the 3rd party developers?
sorry i dont mark them
may be a mistake!
Hi, there is a fork of the unmaintained bar card repository. Maybe see if you experience the same problem with that.
  • Uninstall the rpository from HACS
  • From the HACS menu, select Custom repositories
  • Add this new one
  • Install Bar Card Fork
  • Refresh and test
Not sure if it will work, but worth a try
When you want to compare the Android app to the browser do not use the desktop. Instead use chrome for Android on the same device. Also as mentioned issues with custom cards can only be fixed by the custom card. The best you can do is keep Android system WebView up to date in the play store and report issues to the custom card author.
Hello, I think I misunderstood something, I apologize for that.
Maybe if I ask the question differently it will be easier to reach the goal. Are there officially supported cards that I could use to replace these custom cards? Could you please help me with this?
I am a old^^ and b fairly new and inexperienced in HA, I was happy to get it working at all.
In the card with the bars I have my values, and in the other field my switching options with helper entities for the entities
Thank you in advance.
This text was translated from German to English using Google Translate
Screenshot 2025-01-18 184902
