Hello, I have been having very strange issues today. Im running the most current Hassos , supervisor 139
Everything seems to be working for the most part, except for some reason my input_boolean 's will not show up at all. Everything is setup like always but they are not available. Any suggestions?
its seems like appdeamon is having issues too, but not as much of a concern at the moment. Ill try to fix one issue at a time.
Thanks for any advice!
corey
18-11-06 04:13:08 INFO (SyncWorker_18) [hassio.docker.interface] Cleanup Docker images: ['homeassistant/raspberrypi3-homeassistant:0.80.0']
18-11-06 04:13:09 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:09 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:09 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:14 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:14 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:14 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:19 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:19 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:19 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:22 INFO (SyncWorker_8) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.81.6
18-11-06 04:13:24 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:24 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:24 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:29 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:29 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:29 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:34 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:34 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:34 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:39 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:39 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:39 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:44 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:44 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:44 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:49 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:49 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:49 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:54 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:54 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:54 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:13:59 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:13:59 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:13:59 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:14:04 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:14:04 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:14:04 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:14:09 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:14:09 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:14:09 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:14:14 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:14:14 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:14:14 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
18-11-06 04:15:13 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-11-06 04:15:13 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.81.6
18-11-06 04:15:21 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-11-06 04:15:21 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 390, in start
resp = await self._request_handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 366, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 106, in impl
return await handler(request)
File "/usr/local/lib/python3.7/site-packages/hassio/api/security.py", line 99, in token_validation
File "/usr/local/lib/python3.7/site-packages/hassio/api/proxy.py", line 202, in websocket
client = await self._websocket_client()
File "/usr/local/lib/python3.7/site-packages/hassio/api/proxy.py", line 141, in _websocket_client
data = await client.receive_json()
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_ws.py", line 266, in receive_json
data = await self.receive_str(timeout=timeout)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_ws.py", line 252, in receive_str
msg.data))
TypeError: Received message 8:1000 is not str
18-11-06 04:15:21 ERROR (MainThread) [aiohttp.server] Unhandled exception
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 410, in start
await resp.prepare(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 300, in prepare
return await self._start(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 608, in _start
return await super()._start(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 367, in _start
await writer.write_headers(status_line, headers)
File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 110, in write_headers
self._write(buf)
File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 67, in _write
raise ConnectionResetError('Cannot write to closing transport')
ConnectionResetError: Cannot write to closing transport
18-11-06 04:15:26 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:15:26 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:15:26 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
18-11-06 04:15:26 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/config access from a0d7b954_appdaemon3
18-11-06 04:15:27 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-11-06 04:15:29 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states/sensor.browns access from a0d7b954_appdaemon3
18-11-06 04:15:30 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states/sensor.browns_next_opponent access from a0d7b954_appdaemon3
18-11-06 04:15:31 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states/sensor.browns_channel_next_game access from a0d7b954_appdaemon3
18-11-06 04:15:41 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<WebSocketWriter.ping() done, defined at /usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py:617> exception=RuntimeError('unable to perform operation on <TCPTransport closed=True reading=False 0x71a37600>; the handler is closed')>
File "/usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py", line 621, in ping
return await self._send_frame(message, WSMsgType.PING)
File "/usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py", line 603, in _send_frame
self.transport.write(header + message)
File "uvloop/handles/stream.pyx", line 671, in uvloop.loop.UVStream.write
File "uvloop/handles/handle.pyx", line 159, in uvloop.loop.UVHandle._ensure_alive
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71a37600>; the handler is closed
18-11-06 04:25:27 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
