Ok, I successfully setup personal picture cards for each room and they were all there, come the morning and away from home, I can no longer see the picture cards, just the buttons. I have checked the configuration script and it is still correct and has not changed since it was working last night, It’s definitely an issue with remote access, as my wife is at home and the pictures show on her phone app but mine just the buttons as shown in the images. How do I get around this issue?? Cheers for any help
Where did you put the pictures?
See: https://www.home-assistant.io/integrations/http/#hosting-files
Alternatively: https://www.home-assistant.io/docs/configuration/basic/#allowlist_external_dirs
FYI I only tries https, just now to see if that was an issue, normally the script for the picture path is http
This is how mine are and they work locally or via Nabu Casa:
image: local\images\lcdrawing.png
Are yours in the same www directory? I’ll thy now
yes, ‘local’ refers to ‘www’.
you need to remove the \images
bit because your files are directly in ‘www’. Sorry, I should have explained that before.
All good. I’m sorry I didn’t explain myself well enough at the start… supposed to be working
