Can someone please post an example of how to integrate Openwaethermap Integration into HomeAssistant?
I have managed for so much integrations now to include into HA, but this integration seems to be integrated within HA without higher priority on documentation.
On
https://www.home-assistant.io/integrations/openweathermap/#configuration
I cannot really see how to integrate the OWM integration into my configuration.yaml.
I ended up to pick the following code from this community
weather:
- platform: openweathermap
api_key: 4c8111bxxxxxxxxxxabfcf6e32f1
and
- platform: rest
json_attributes_path: "$.daily[0]" # 0=today
json_attributes:
- temp
value_template: "{{ value_json['current']['dt'] | timestamp_custom('%Y-%m-%d %H:%M', true) }}"
resource: https://api.openweathermap.org/data/2.5/onecall?lat=5x.xx3679&lon=1x.xx6408&appid=4c8111bc7xxxxxbfcf6e32f1&units=metric&lang=nl
scan_interval: 3600
and further down, I have several template sensors:
sensors:
openweather_maxtemp_today:
value_template: "{{ states.sensor.openweather_report.attributes.temp.max }}"
The fault in my log shown is
The openweathermap platform for the weather integration does not support platform setup. Please remove it from your config.
So maybe I have issues with my OWM config?
I really would appreciate, if the a.m. Integration page of OWM can be added with some more examples on how to add it to the configuration.yaml. Only the basic setup. I burned huge amount of hours at this point.
Regards,
Jörg
