Hi
I have installed the latest update to the Duck DNS addon to 1.14.0 and I got an error when trying to start the addon - Missing option ‘algo’ in lets_encrypt in Duck DNS (core_duckdns).
Do I need to add an algo parameter in Duck DNS?
Hi
Had the same and indeed solved it by adding algo:
lets_encrypt:
accept_terms: true
certfile: fullchain.pem
keyfile: privkey.pem
algo: secp384r1
Same I noticed this section in the docs:
lets_encrypt.algo
(optional)Public key algorithm that will be used.
Supported values: rsa
, prime256v1
and secp384r1
The default is secp384r1
Thanks. That has fixed it.
Thanks for the solution.
The documentation should be updated as the algo field is still showing as optional.
algo: secp384r1
Had exactly the same problem after upgrade.
to add
algo: secp384r1
really solved the problem!
Thanks for sharing the solution here!
Same issue here!
Same issue here, problem is I can’t edit it in the app on mobile. Every time I try to edit it the cursor jumps or doesn’t paste what I want to paste completely or does it in a weird spot.
Hi all, could you tell me where put this exactly?
lets_encrypt:
accept_terms: true
algo: secp384r1
Now I’ve only
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
THANX
This
seems your HA configuration.yaml. It is not there.
This :
goes into the configuration of the duckdns add-on.
I’ve solved with algo: secp384r1 in duckdns yaml
THANX
I get the same behaviour trying ti edit on Ipad or iPhone, had to use my mac to edit the config.
algo: secp384r1
solved the problem also for me, thanks for posting here !
Yes, confirm. Solved adding the line
algo: secp384r1
Super helpful. That sorted my issue as well.
Thank you!
Great, this solved it for me too, thank you!
