good morning, everyone
i’m trying to create a google TTS in nodered combined with home assistant tts.google_say service call but for some reason nodered does not display the entity_id field once i selected tts.google_say call service. If i select a different type of call service like light.turn_on for example, i have the option to pick out an entity_id.
It goes in the data section. The little button towards the bottom on the right, “Load example data”. Click that button and it will load the format in the data section. Then click the 3 dot button at the right of the data field to edit.
my man thank you very much for point in the right direction. that did the trick
