I’m stumped over this error I’ve been having pretty much since the beginning where I’ve been using Home Assistant and ESPHome.
The relevant section of code is:
esp32:
board: esp32dev
framework:
type: arduino
version: 2.0.6
This configuration “works” but generates an error:
“WARNING The selected Arduino framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.”
If I remove it altogether:
“MissingPackageManifestError: Could not find one of ‘package.json’ manifest files in the package”
I also tried changing “version: 2.0.6” to “version: latest” but it still generates the error:
Web searches suggest deleting various directories but I’m not finding these directories when I go into the Terminal Server.
I’m running Home Assistant as a VM on server hardware that’s running Windows 2019 Server as the base OS.
I used haos_ova-10.3.vhdx as the virtual hard disk for Home Assistant.
Can someone point me in the right direction to solve this issue?
Thanks in advance.
