Missing "--pid-file path_to_pid_file" and "--daemon" options form my init service
just pointed that the options are missing, but how to replace it?
You don’t use a startup script?
Just ran into this issue with my freebsd startup script…
I used it as startup via init.d services, but now the startup script doesn’t work as the part with PID a DAEMON doesn’t get any values anymore
I’m pretty sure you could adapt your SystemV script to not use daemon/pid, but it has been superseded by SystemD, anyway.
See below for a guide where you don’t need those parameters
lol, thanks, now it works, not sure why as there is no activation of python’s vEnv, but it works, thanks
For anyone looking for an updated SystemD script that doesnt use venv, here is the one I hacked together last night:
#!/bin/sh
# $FreeBSD$
# PROVIDE: hass
# REQUIRE: LOGIN
# KEYWORD: shutdown
# Add these lines to /etc/rc.conf.local or /etc/rc.conf
# to enable this service:
# hass_enable (bool):      Set to NO by default.
#                          Set it to YES to enable home-assistant.
# hass_user (user):        Set to hass by default.
# hass_group (group):      Set to hass by default.
# hass_config_dir (path):  Set to /usr/local/etc/home-assistant/ by default.
. /etc/rc.subr
name=hass
rcvar=${name}_enable
command="/usr/sbin/daemon"
load_rc_config $name
: ${hass_enable:=NO}
: ${hass_user:=hass}
: ${hass_group:=hass}
: ${hass_config_dir:=/usr/local/etc/home-assistant/}
logfile="/var/log/${name}_daemon.log"
pidfile="/var/run/${name}_daemon.pid"
HA_CMD="/usr/local/bin/hass"
HA_ARGS="-v --ignore-os-check --config $hass_config_dir"
start_precmd=${name}_prestart
start_postcmd=${name}_poststart
stop_postcmd=${name}_poststop
status_cmd=${name}_status
hass_prestart() {
  install -g "${hass_group}" -m 664 -o ${hass_user} -- /dev/null "${logfile}"
  install -g "${hass_group}" -m 664 -o ${hass_user} -- /dev/null "${pidfile}"
  rc_flags="-f -o ${logfile} -P ${pidfile} ${HA_CMD} ${HA_ARGS}"
hass_poststart() {
	sleep 1 ; run_rc_command status
hass_poststop() {
  rm -f -- "${pidfile}"
hass_status() {
  if [ -n "${rc_pid}" ]; then
	echo "${name} is run as as pid ${rc_pid}."
  else
	echo "${name} is not running."
	return 1
  fi
run_rc_command "$1"
