I updated to Home Assistant OS 12.4 and the Samba Backup add-on is giving me this warning:
Missing repository for an installed add-on
Repository for add-on Samba Backup is missing. This means it will not get updates, and backups may not be restored correctly as the supervisor may not be able to build/download the resources required.
Please check the add-on’s documentation for installation instructions and add the repository to the store.
If you are having a problem with a specific add-on, the first point of contact is in the Github post that you found it in originally.
Most if not all the people there that know the product and use the software that will be able to give you more accurate information regarding your problem.
