I run Home Assistant in a VM. Some time ago, I upgraded home assistant, I noticed that the some items in home assistant sidebar was missing (red box below). However, I could see that the corresponding addon was running. Those missing item came back after I restart the home assistant (restart server in home assistant website, not restarting the VM).
thank @os.habitats.tech. how do I let the browser refresh? I am using chrome I tried clear the cache. But it didn’t seem to solve the problem. Another data point is that, the andriod app has the same issue.
It is somewhat annoying to login again after restarting the server because it happens everytime I restart the VM. I am still playing with it and does restart a lot to iron out a boot problem when Coral USB is plugged in. But I appreciate your help.
It’s happening to me consistently when the PC running Home Assistant (on VM) reboots. I have to restart Home Assistant after boot to refresh everything.
I also have this problem. All addons are running, and it dosent matter if I use the mobile app or a browser. Clearing cache / ctrl + F5 is not solving the problem, only restarting HA (not HAOS).
I’ve tried install a new VM with a clean HA and restored a backup, same issue! Updated up to 2024.8.3, did not solve the problem…
