Missing some Python libraries. Can I repair without having to reinstall?
Recently Python on my Raspberry Pi 4 - running HA Core - got messed up. Home Assistant is mostly working the exception of an integration that uses Bluetooth. Is there a list of Python versions and libraries that I can check to make sure are properly installed?
Thanks uncapped_shady.
Thanks. Is there an equivalent comment for home assistant core?
Where are you getting this information from??? This is made up too. This is the second post of yours that has blatently wrong information. Please stop posting miss information. If you’re using ChatGPT, stop posting it’s responses as definitive answers.
@Kevin619 do not listen to his responses, they are not correct.
Thanks. Are there any equivalent comments for HA Core?
