Level ; beginner
I installed a dual boot dual drive system
Smooth install until I received the following response:
WARNING: The script slugify is installed in ‘/home/homeassistant/.local/bin’ which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
WARNING: The script normalizer is installed in ‘/home/homeassistant/.local/bin’ which is not on PATH.
WARNING: The script httpx is installed in ‘/home/homeassistant/.local/bin’ which is not on PATH.
WARNING: The script hass is installed in ‘/home/homeassistant/.local/bin’ which is not on PATH.
I am stuck !
what to do ? where to start
Thank you
