kharuda
1
I am newbie in HA and I have HA installed in VirtualBox and I missing SUN (sunrise and sunset) sensor.
I searched for it on google but no help
I have
Home Assistant OS 7.4
core-2022.2.8
supervisor-2022.01.1
Does anyone know what it is?
Thak you
Karel
tom_l
2
The Sun integration can not be set up via the user interface.
You have to add it to your configuration.yaml file as per:
Itβs also in default_config. So if you have that in your configuration.yaml file you do not need to add the sun integration.
kharuda
3
I have the
sun:
in the config file, but it doesnot works. It has start working after adding to config file
homeassistant:
latitude:
longitude:
elevation:
Now it works
Thank you
