Hi.
I got two sets of Aeontec LED Stips(ZW121-B) that I am trying to use. They are showing up as unknown on OpenZwave when I add them to the network. After looking at it, it looks like the product is on the OpenZwave DB. https://products.z-wavealliance.org/products/1999
So I am thinking that my Product Type ID may be different from the ones in the manufacturer_specific.xml.
If you use ozw-admin, the Node Info pane shows you the product id and type. Otherwise, you can use something like MQTT Explorer and look into metadata for the node.
I looked on ozw-admin, it shows nothing on the node info page, I attached a pic. I also looked in MQTT Explorer and I can see anything that stands out, do you know where I need to look on the node for the info?
I contacted Aeontec and I have the device now showing correctly in OpenZwave, But homeassistant only shows it as a light that I can change the brightness off. How do I get homeassistant to show it a RGBW so I can change the colors?
I think I got it working, I had to change the setting in the Config Value " Report when the Color is changed", it was set to Disabled and I change it to Hail CC. Now if I switch it on the card change in HS and allow me to change the colors. Not sure if this is how it is meant to work.
Just happy I got it configured and can change the color now.
Here is my User and System Values
I am in the same boat, trying to get colors to work with the openzwave integration. It used to work, but I did a factory reset (and re-included all devices securely) so maybe it was some setting. Trying HAIL CC for the “Report when color is changed” mode now.
Update: I am seeing less user / system values than you are (via openzwave / ozwadmin). Will try to see what happens when I run OZW admin directly on a laptop with the stick plugged in.
Finally have it all up and running. I kept it included securely, but more nodes were not correctly included.
I am using the OpenZWave beta integration and I did a full reset of the whole network and included all the nodes 1 by 1 on the same day. It took several days and explicit device refreshes for the whole network to come up with all features enabled, but all seems to be working solid now!
