I lost the developer’s panel and the logout option. Any ideas on how to get it back? I’ve tried rebooting but that didn’t help.
If this is Hassio, you are also missing that menu.
What have you tried?
What do the logs say?
When did you first notice this?
How do you expect any assistance if we do not know what you have tried and have no information to work from?
and probably more importantly, what did you do right before it went away?
That’s where I would start looking.
Before my last reboot I was playing around with the node-red configuration - trying to get the node-red link to work. I think I set the username and password in the node-red configuration.
Now that I can’t access the node-red configuration or any of the packages I’m not sure what to do?
Can you ssh in? (ie do you have the ssh add-on installed?) If so, make sure the supervisor is up to date. There is also a cli option to check the config and see if you broke something while working on node-red.
Thanks for help! I was able to ssh in and reload my last snapshot!
