Noticed my Zigbee2MQTT is outdated in a supervised HA installation.
Supervisor does not show any available updates.
Does anyone else have the same issue?
The repository has moved and the old one is not updated anymore.
This is the current and up-to-date one:
It used to be this one:
You need to add the addon from the new repository, turn off the old addon. Copy your settings from the old addon’s settings place to the new one’s and start the new addon. After you have confirmed that everything is working with the new, then you can remove the old addon.
Thank you, worked like a charm
Please could you let me know how to copy the settings, is it just the entries under Config? Will it automatically find all the existing devices? I have a lot and am worried about loosing it all.
For home assistant, you need to check the integration settings you currently have
For Zigbee2MQTT, I copied the /share/zigbee2mqtt files.
Please note that some integration settings might be deprecated. So read them through.
For me, nothing broke.
I keep running into “Invalid Add-on repository!” when using the link provided on the repo’s readme (https://github.com/zigbee2mqtt/hassio-zigbee2mqtt). Anyone else have this issue/fix?
Edit: Fixed my own issue. Basically the HA app uses the external link which for some reason doesn’t work (I need to look into this), but the local link worked. Just thought I’d add this in case anyone else is stuck.
