Anyone else missing the x to close the more-info window? clicking the left top spot in a more-info closes it, but there should have been the X?
this is on the updated App 2020.1(17) and HA 0.111.2
Still seeing the X using App 2020.1(17) and HA 0.110.7.
Have you tried the default theme to make sure it’s not your theme obscuring the X?
yes, I have tried all themes
no X in sight.
also, this is only in the app, if I use a mobile browser, even Safari, the X is there.
An app issue that only shows up if using HA above v0.110.7?
by some automagical force the X’s have re-entered the frontend in the App… how odd this is. Probably a cache thing?
marking this as solved.
Unexplained weirdness is always a cache thing
