Hi!
I’m running HA, currently on 100.3. I have a Aeon z-stick, and a number of Z-Wave devices that works more or less perfectly.
I bought a ID Lock with a Z-Wave module, which I’ve installed and successfully included into my Z-wave network. I can control the device, and I get some updates back. So far so good.
I’m trying to get who opened the door, but I can’t find that information in my entities. According to the documentation (pdf) the notification type 0x06 is updated as the entity sensor.id_lock_as_150_access_control works great. How ever, I need to get the event parameter as well; because that’s where the user ID is stored (I know that part works; I see the ID:s in the OZW_log.txt).
I figured that I check the zwave.node_event event, but I can’t get HA to listen to that topic. I’ve tested to add a listener through the developer tools, but it does not show any events.
EDIT: I’ve also tested to add this automation, but it made no difference.
automation:
- alias: "Log any Z-wave activity"
platform: event
event_type: zwave.node_event
service: logbook.log
message: "{{ trigger.event.data }}"
Do you have any ideas of what to do to get those events?
Thank you!
Zyber
