i’m pretty new to HA and get more and more impressed, how good it is. Currently I’m working on Scenes with my Zigbee lights.
I got 4 dimmable/warm-to-cold-white LEDs from manufacturer Paulmann (type 50064), which are fully supported by zigbee2mqtt.
The problem is I dont have the control attributes for dimming and warm/cold-white controls, only On/Off. So the further problem is, I cannot use all attributes in automations, scenes and so on.
Think this is as expected and fully working. If you press on “EG-Wohn…” when the bulb is in on mode, it should open the light pop-up, where you can set the color etc.
You can do the same in the scene mode. It will store the attributes.
