Mistakenly removed Aeotec 5+ z-wave stick to inclusion on far away place
Unfortunatly i did this
Warning:
  1. Do not move your Z-Wave stick to include devices. This is no longer necessary and leads to broken routes.
  2. Do not initiate device inclusion from the Z-Wave stick itself. This is no longer supported.
and nothing works anymore. I need guide how to reverse.
I use JS-zwave on Odroid N2+ Home Assistant Blue
What have to be done to stick?
Wat have to be done in HA.
Apreciate eny help
Regards
What problems are you having now that you’ve done this?
Thank you for your help, much apreciated! First I installed 4 z-wave devices that worked great. Then I installed one more with the stick in my garage. After this none of the 5 devices works anymore. HA reports “zwave command failed”. Now not sure what to do, maybe factory reset on the Aeotec stick?
I restarted HA and JS.
Regards
What do your zwave logs say? Have you tried healing and/or restarting the zwave network?
Upp and running again after restart zwave network.
Thank you!
Of course, coming from openHAB, this is exactly what I did as well, because of the “well, that’s how we always did it” pitfall. A restart did the trick, thanks!
