Unfortunately you have to compile your own as default tasmota bin doesn’t include the mitsubishi library.
It’s not very difficult but you do need to research a bit.
I do it with a docker container created by blackadder https://hub.docker.com/r/blakadder/docker-tasmota
There’s also a Web page to do this. You’ll find ‘how to’ videos in you tube
After digging deeper, I found that compiling tasmota bin in Gitpod was way easier than I thought. I said I didn’t know how cuz I couldn’t get it to work with ESP32 WROOM. I got some 8266 yesterday and used tasmotizer to load the bin and it worked right away.
Let me answer my own questions here which may help some others.
The Italian page that @JuanSA00 posted was by far the easiest. Used google translate and I didn’t have a bit of problem following the instruction. It took about 20 min from downloading the first software to connect to HA. Once added to HA, the card shows right up, no extra codes need to insert.
Tasmota route requires to add codes in configuration.yaml for each one and add card manually. If you want to use Tasmosta and doesn’t know much about ESP, use something that tasmotizer supports like ESP8266, not ESP32. Follow the instruction from https://isaiahchia.com/ and download the bin file which was based on tasmota 11.1. Or if you want to use the latest version, watch this https://www.youtube.com/watch?v=WashxTcHiDc&ab_channel=vccground
I like how you’ve put your header board on so that the pins extend out to the side (and not up or down). I’m thinking this would make the installation a bit easier.
Interesting. I am not sure if you are talking about using dumb remote and receive update which I have not tested. If I control everything through esp The status update is about 1 second lag for me. The only issue is quickly changing settings does not work the smoothly.
Hi, anyone who has modified a newer mitsubishi heat pump with built in wifi? Is it the same process just that you need to remove the built in wifi unit first?
Today I modified an MSZ-AY with the Swicago software. I removed the Melcloud WiFi from the CN110 connector and connected the ESP to the CN105 connector.
I successfully added ESP8266 Wemos D1 Mini Pro to ESPHome and add a Climate Component to Home Assistant. Controlling of the Mitsubishi Electric MSZ-FH25VE works (baud rate is 2400!)
I noticed that now I can create an automation to change the mode [HEAT_COOL, COOL, HEAT, FAN_ONLY], but there is no possibility to adjust temperature in automation. Temperature can be adjusted manually through the HA UI from Climate Component.
My question: Has someone found a way to add temperature control also to the HA Automation?
EDIT: Thanks Jesse! This works now:
Service as the action, then pick Climate: Set target temperature
My ESPHome yaml is here and couple of pictures.
And one hint:
I need to reboot my RaspberryPi 3 every time before I compile the ESPHome code or otherwise compilation fails!
esphome:
friendly_name: ESPHome ILP YK
esp8266:
board: esp01_1m
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "REPLACE_WITH_YOUR_OWN_KEY"
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "yyyyyyyyyy"
password: "xxxxxxxxxx"
captive_portal:
# Enable Web server.
web_server:
port: 80
# Sync time with Home Assistant.
time:
- platform: homeassistant
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
# Sensors with general information.
# Uptime sensor.
- platform: uptime
# WiFi Signal sensor.
- platform: wifi_signal
update_interval: 60s
external_components:
- source: github://geoffdavis/esphome-mitsubishiheatpump
climate:
- platform: mitsubishi_heatpump
hardware_uart: UART0
baud_rate: 2400
update_interval: 1000ms
visual:
min_temperature: 15
max_temperature: 30
temperature_step: 1.0
I was wondering if anyone knows if multiple devices can plug into the CN105 port. I currently have a redlink thermostat connected to the HVAC that way and was wondering if a simple splitter would allow both a D1 Mini and the Redlink Adapter to both be connected to the same port
Edit: After some research I am going to guess no. It uses UART which doesn’t allow for multiple devices. A way it could work is to Daisy chain them with a multiple UART bus device in the middle. But that isn’t supported currently.
I’m using D1 mini clones and when I use the web interface of esphome the AC works and I can view the info of AC but in homeassistant everything is unavailable.
Can be the problem in Tx Rx? Or something in esphome config? Because is strange to work using the web interface.
WARNING acquartoesquerdo: Connection error occurred: Ping response not received after 90.0 seconds
INFO Processing unexpected disconnect from ESPHome API for acquartoesquerdo
WARNING Disconnected from API
INFO Successfully connected to acquartoesquerdo in 0.387s
INFO Successful handshake with acquartoesquerdo in 0.022s
