@alex5 . Thank. you for posting this.
I’m trying to use your code, but I’m getting an error when getting the device data.
I’m able to use this to get my Context Key:
@alex5 Your script is working correctly, so I don’t know what’s wrong with the last curl , but I don’t care.
Did you manage to get those sensors in the energy dashboard?
@vilppuvuorinen I’m integrating those values in the pymelcloud repo, and I will submit the PR
@gn3sh I’ve added the utily meters to get the values in Energy Dashboard. I’ve renamed the rest sensor to be consistent with the daily utility meter sensors.
- platform: rest
resource: https://app.melcloud.com/Mitsubishi.Wifi.Client/user/ListDevices?id=61484&buildingID=20719
method: GET
headers:
X-MitsContextKey: "CONTEXTKEY"
value_template: "OK"
scan_interval: 60
json_attributes_path: "$..Devices[?(@.DeviceID==DEVICEID)].Device"
json_attributes:
- CurrentEnergyConsumed
- DailyHeatingEnergyConsumed
- DailyCoolingEnergyConsumed
- DailyHotWaterEnergyConsumed
- DailyEnergyConsumedDate
sensors:
heat_pump_power:
friendly_name: "Heat Pump Power"
# availability_template: "{{ is_state('sensor.heat_pump_api', 'OK') }}"
availability_template: >-
{{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'CurrentEnergyConsumed') != None) }}
value_template: "{{ state_attr('sensor.heat_pump_api', 'CurrentEnergyConsumed') }}"
device_class: power
unit_of_measurement: "kW"
heat_pump_heating_energy_consumed:
friendly_name: "Heat Pump Heating Energy"
{{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'DailyHeatingEnergyConsumed') != None) }}
value_template: "{{ state_attr('sensor.heat_pump_api', 'DailyHeatingEnergyConsumed') }}"
device_class: energy
unit_of_measurement: "kWh"
heat_pump_cooling_energy_consumed:
friendly_name: "Heat Pump Cooling Energy"
{{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'DailyCoolingEnergyConsumed') != None) }}
value_template: "{{ state_attr('sensor.heat_pump_api', 'DailyCoolingEnergyConsumed') }}"
heat_pump_hot_water_energy_consumed:
friendly_name: "Heat Pump Hot Water Energy"
{{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'DailyHotWaterEnergyConsumed') != None) }}
value_template: "{{ state_attr('sensor.heat_pump_api', 'DailyHotWaterEnergyConsumed') }}"
heat_pump_energy_consumed:
friendly_name: "Heat Pump Total Energy"
((state_attr('sensor.heat_pump_api', 'DailyHotWaterEnergyConsumed') != None) or
(state_attr('sensor.heat_pump_api', 'DailyHeatingEnergyConsumed') != None) or
(state_attr('sensor.heat_pump_api', 'DailyCoolingEnergyConsumed') != None) )}}
value_template: "{{ state_attr('sensor.heat_pump_api', 'DailyHeatingEnergyConsumed') + state_attr('sensor.heat_pump_api', 'DailyCoolingEnergyConsumed') + state_attr('sensor.heat_pump_api', 'DailyHotWaterEnergyConsumed') }}"
utility_meter:
heat_pump_daily_energy_consumed:
source: sensor.heat_pump_energy_consumed
name: Heat Pump Daily Energy Consumed
cycle: daily
heat_pump_daily_heating_energy_consumed:
source: sensor.heat_pump_heating_energy_consumed
name: Heat Pump Daily Heating Energy Consumed
cycle: daily
heat_pump_daily_cooling_energy_consumed:
source: sensor.heat_pump_cooling_energy_consumed
name: Heat Pump Daily Cooling Energy Consumed
cycle: daily
heat_pump_daily_hot_water_energy_consumed:
source: sensor.heat_pump_hot_water_energy_consumed
name: Heat Pump Daily HotWater Energy Consumed
cycle: daily
I see Energy recovery ventilators are not supported yet, will they be supported in the future? I want to install the mitsubishi air-water heatpump and maybe the Lossnay ventilation system.
With this code I get very big consumption numbers - 16000kwh per day. It seems that DailyEnergyConsumedDate parameter is read regularly and constantly added throughout the day, but it should be added once a day. Do you have any ideas how to fix it?
This one is the same - OK.
I changed the names of variables and now the states of this variables are looking normal. But in Energy Dashboard no data for now. I believe that it will appear in 24 h. Thank you for trying to help!
A question about the heat pump.
By entity water_heater.heatpump
I have a switch to power down the heat pump.
I made an automation to power down the heat pump when reached the 50 degrees Celsius.
I want to make an automation to power down when reached the attribute “temperature”
I’m a Newbie. How to do this?
i have the same unortunately, sometimes zero and whatever i do it keeps messing with the utility meter. annoying that it updates once per day, 2 minutes after midnight for me as well
Could someone tell me if the energy consumption readings are fixed now? I have air-to-air option with updated firmware but when I compare the consumption between the MELCloud app and HA I see 1.2kWh from the app and 0.2kWh from HA. Do you know about an alternative or the fix to that? What should I do?
I am having challenges with the heater operation mode.
I can see the current mode from MELCloud, but i cannot change it in HA.
cool, heat, off, curve, flow are all not selectable.
@ptaqp A fix for the energy meter issue is in the works. It has been a nightmare to get the new home-assistant dev container setup working and it has delayed the fix quite a bit.
@MMouse There has been a feature branch open for a year (or two?) that would split the air-to-water device into mode specific thermostats to align things with the way the device is modeled ln MELCloud. It’s just a pain the get it working without having access to a device.
