Yes. Based here in Portugal and the HA MELclould integration has been fubar since early this evening … however I can still control AC units via the MELCloud mobile app & http://app.melcoud.com
I’ve been experimenting with ESPhome and this current hiccup has solidified my mind to go down the local control route.
It’s interesting: i can control my devices via app (android), but only on devices, which are already connected. New login doesn’t go through…after a while i got that it’ not possible to login…
and, as you said: web page also works.
You have the point in esphome option…i’ll look into it, too. But, only one my device has external wifi module, other two have integrated, so i’ll have to dig a bit if esphome option is even possible in this case.
Open up your units and take a look? I recently bought 2x ACs with ‘integrated wifi’ and it’s just the same wifi dongle buried inside the casing! The control socket / CN105 / JST-PA5 / wtf the plug type is called … is the same.
I’ve been testing ESPHome with a couple of spare $10 dev boards I have kicking around w/ this repository installed: https://github.com/geoffdavis/esphome-mitsubishiheatpump … seems easy enough, just waiting for the correct cables to arrive later this week.
How does that work with esp? You can replace the wufi dongle? Is there any more info available?
However I almost never control my heatpump. Its Air to water heatpump that heats my house and hot water. Its mostly a set it and forget it kinda setup. However I do like collecting statistics and saving it in HA.
Yes exactly. The ESPHome HA integration & some hardware replaces the MELCloud HA integration & Mitsubishi Wifi dongle.
You need any flavour of ESP32 dev board (mine is this one: https://wiki.keyestudio.com/KS0413_keyestudio_ESP32_Core_Board), some custom software (from github, link in my previous comment / below), and requires a DIY cable … which plugs right into the same socket as the Mitsubishi dongle.
I’ll reply back once I get it running (later this week), just awaiting parts to make the cable.
It depends on what you mean by “nice” and “control”. If you want full control, I believe the panel you’re seeing is as good as it gets, at least without crafting something totally custom yourself.
For just turning on/off and adjusting the temperature, the Mushroom Climate card works well on my mobile app interface. (Bottom half of screen here.)
I’m sure there are prettier UIs out there, and I’d love to see what other folks are doing, but this is more than fine for me. I don’t need to adjust fan or swing very often, and the operation mode only a couple times a year.
Hi, did you and vilppuvuorinen make any progress with fine tuning the control and EffectiveFlags? I have managed to get your on/off switch to work, but it would be awesome to be able to fine tune some of the other settings too by a more finely tuned script?
Which Mitsubushi device should I buy in order to integrate it into HA?
Is the Basic “HR” edition enough, which comes without a wifi module? If so, do I have to add a original Wifi Module of addition 150 € from Mitsubishi? Or is an esphome enough?
Or should I directly go with the Advanced “AY” edition, which already has the wifi module on board?
Is it possible to connect to the Melcoud with a custom CN105 / ESPhome device? Or would the melcloud definitely require an original mitsubishi wifi connector?
