It is not integration because values are stuck in response from service.
It is working again
thereās an really easy way to connect to the mitsubishi heatpump using the cn105 port without the need to solder. Iāve created an esphome version of ecodan ha local with some improvements. Iāve also made a howto.
Very cool. But I would have now way of figuring this out, even with the documentation. To much implicit knowledge is required.
Iām running HA in a docker on my Synology. If there isnāt a ready made integration, I would have no idea how to make it work.
Does it also work with Mitsubishi A/C Units?
Can it co-exist with the Mitsubishi WiFi Module, for MelCloud integration?
Is anyone else having issues controling AC and not responding to commands?
In the official app there is also an error:
Last communication with system: 20:55:02
Similar. The last data from MELCloud integration in HA was yesterday (18. 4. 2024) around 20:30 CET. I also checked MELCloud and it stopped recording data at the same time. Looks like an issue on their servers.
@snowatom I donāt know how I can make it easier, you just need
- m5stack atom s3 lite
- grove cable
- cn105 connector and replace one side of the grove cable
- build the firmware and flash
@uspino
Yes it will work voor A/C units, but you need to use different firmware. something like GitHub - SwiCago/HeatPump: Arduino library to control Mitsubishi Heat Pumps via connector cn105 and set the correct tx/rx pin and you are good to go. It cannot co-exist with melcloud.
I have the same issues with HA but even with the melcloud app (via android or pc).
I reset the wifi but no change.
the wifi mode shows 2 orange lamps every 5 seconds,ā¦ āno connection to melcloudā.
I feel there is an issue with the cloudā¦ I opened a ticket
Last communication with system: 18:24:30
Iām about to email them. Really tempted by the local CN105 connection now!
Hi
We have a server issue the team are working on a fix to resolve the issue.
Note:Please Follow Your Companies Safe Working Practices And Health And Safety Policies
Kind Regards
Same troubles here. In fact of my 4 units, two of them with the old MAC-557 interface are working fine, the other two (MAC-567 and MAC-587) are cold dead.
I think that the problem is that old units use a different server (leswifidata.meuk.mee.com) than new one (production.receiver.melcloud.com), the latter is KO.
Waiting for Mitsubishi solving the problemā¦
Do that, you wonāt be dissapointed. Iām past their constant āserver dropoutsāā¦if your device is supported, go for it. You have nothing to loose, if it wonāt work you can always go back to cloudā¦
Down again I guess.
Will do the esp stuff some day. Since I am only doing monitoring its not that important to me.
Do you have the official link to the status update ?
It was on melcloud page.
@gekkekoe Will the Atom Lite (C008) work? It has G26 and G32 at the connector instead of G1 and G2ā¦
Itās the only one I can find aroundā¦
@uspino yes should work, the hy2.0-4p (= grove plug) uses 5v, thatās whats the cn105 is giving (it also gives 12v, but thatās not needed). basically all m5stack boards that have grove plug should just work (the level shifter from 5v ā 3.3v is included)
you need to adjust the 2 following parts in the yaml
change
packages:
remote_package:
url: https://github.com/gekkekoe/esphome-ecodan-hp/
ref: main
refresh: always
files: [
confs/esp32s3.yaml, # confs/esp32.yaml, for regular board
confs/zone1.yaml,
## enable if you want to use zone 2
#confs/zone2.yaml,
to (you could also enable zone 2 if you have it)
packages:
remote_package:
ref: main
refresh: always
files: [
confs/esp32.yaml,
confs/zone1.yaml,
#confs/zone2.yaml,
you probable should try the regular esp32.yaml
and set pins:
ecodan:
rx_pin: GPIO2
tx_pin: GPIO1
to
ecodan:
rx_pin: GPIO26
tx_pin: GPIO32
If it does not work or if you are having issues, feel free to open an issue on my github, Iāll try my best to assist. report back if it worked, then I will included the board as tested.
Thanks, Iāll report back in a few days. Iām tired of MelCloud poor reliability.
