I have a mixed group view containing Hue lights, mqtt_json controlled lights & switches. However the Control for switching off/on the whole group only effects the Hue Lights and not the others.
Is it possible to control ALL lights in the same group?
I have some limitlessled and some mqtt light mixed in a group, both on/off and color control work fine for the whole group.
Could you try without switches in the group?
Do you see any error in log when you change the group switch state?
Thanks. I tried lots of different things and restarted lots of times and it now works. I don’t know what was wrong.
Faces the same problem with:
WZ:
entities:
- light.knx_lichtsockel1
- switch.no02
- switch.no03
Before switching to Tasmota integration I had definde the last two Gosund plugs as MQTT Lights and everything went well.
I understood that in gerneral mixed groups are possible right ?
Any hint, would be welcome.
THX M
