I can browse to my CCTV camera stream via NX Witness, using API testing tool - Nx Meta Developer (nxvms.com).
I can then successfully added it to Home Assistant
But the feed does not come through.
Nothing appears in the logs other than a warning about not adding certificate verification (which is not an issue in this case).
