you could just try and start with getting a picture, so you know the communication works fine with HA. Might want to also do "’ on the url of mjpeg and also check if you use the stream component or not since that requires a good ffmpeg version.
Thank you so much for the response. Be honest with you I think the issue is with the links to my cameras which are in https and since I don’t have any SSL certificates on my HA I think it doesn’t load them. I really don’t know how to work with SSL in HA do you know where I can start?
