I follow Andreas’s advice now and use his “priority #1” pins (~ 05:53 in vid).
Way fewer headaches and rooky pin schema mistakes since I’ve started doing that.
Hlktech / Hi-Link has a few 24G mmWave sensors:
Has anybody tried to work with them?
We look forward to hearing your reports on the [insert random aliexpress sensor here]
Hey,
i have HLK LD1115H working with my Wemos D1 mini.
It detects Movement and Presence, also doing it blazingly fast.
Can you tell us more about it?
The Hi-Link site has some detail but brings up a few more questions:
We have learned from our SeeedStudio experience that the details can make or break a sensors use-case flexibility.
Disclaimer: I am a noob.
So I bought these sensors as DFrobot was soldout everywhere.
To answer all your questions:
I hope someone with real programming skills could make it more adjustable, as I only managed to set it to report static body detection and movement, without any adjustments.
Thanks for the details.
I think I follow now regarding the angles.
Have you tested static presence beyond 2M? I think that’s the biggest consideration.
For some reason I don’t see the datasheet available for download. Did you have to contact them? Can you share?
I just contacted them on AliExpress and they sent me the datasheet.
Additional info: i just have tested static presence. Up to 5m it detects presence with no issues so far. above that not so well.
I’m thinking of getting HLK-LD1115H too, mine sharing your code in ESPHome?
I would also love to see sample esp home code when you have time to share.
I’m getting “mov” and “occ” values through the debugger finally using the HLK-LD1115H. I tried to set up a binary_sensor like the DFRobot config here: ESPHome Config for DFRobot mmWave SEN0395 Sensor (github.com) but I can’t get it working yet.
uart:
tx_pin: GPIO4
rx_pin: GPIO5
baud_rate: 115200
debug:
direction: BOTH
dummy_receiver: true
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
binary_sensor:
- platform: gpio
pin: D2
Since this is a different sensor, it likely requires a different solution.
Would recommend posting a separate thread including;
Yes, me three. My current pir setup needs improvement.
Hi. Thanks for all the effort and assistance in this project. I’ve connected the dfrobot sensor with a d1mini esp32 board and everything works as expected. Unfortunately when I tried to turn off the blinking led on the sensor, the code seems to go through but the led still blinks. Is there some specific gpio pins i need to use for disabling the led. Below are the pins i’m using. Everything else is the same as your code. Thank you.
binary_sensor:
- platform: gpio
pin:
number: GPIO16
mode: INPUT_PULLDOWN
- platform: adc
pin: GPIO35
name: "Master Bedroom Illuminance"
update_interval: 10s
unit_of_measurement: lx
attenuation: 11db
filters:
- lambda: |-
return (x / 10000.0) * 2000000.0;
uart:
tx_pin: GPIO22
rx_pin: GPIO21
baud_rate: 115200
debug:
direction: BOTH
after:
delimiter: "\n"
sequence:
Make sure you have the TX and RX pins the correct way would be my first guess
Hmm the TX pin on the sensor is connected to GPIO22 and RX pin is connected to GPIO21. Do i need to go with another GPIO pins?
You will want to make sure that it looks like: TX → RX & RX → TX
here is mine setup:
uart:
rx_pin: GPIO3
tx_pin: GPIO1
baud_rate: 115200
stop_bits: 1
# debug:
text_sensor:
- platform: custom
lambda: |-
auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
App.register_component(my_custom_sensor);
return {my_custom_sensor};
text_sensors:
filters:
- lambda: |-
if(x=="mov") {
id(mov_binary_sensor).publish_state(true);
id(mov_binary_sensor).publish_state(false);
if(x=="occ") {
id(occ_binary_sensor).publish_state(true);
id(occ_binary_sensor).publish_state(false);
return x;
binary_sensor:
filters:
- delayed_off: 2s
filters:
- delayed_off: 2s
Yep as @crlogic says you need to make sure you are not going RX > RX and TX > TX, they should be the other way around
