mmWave Presence Detection - ESPHome style
Does it mean you can identify different areas of movement?
Hi @crlogic
Can you explain a bit what you are trying to do and how you get those values ?
if target = person then I would say match with number of person of the house.
SNR means ?
Yes you can differentiate by distance.
That’s the plan. Need to finish testing and use-case writeup.
Negative. Target != person. Target = detectable motion above noise threshold. Aka, wave two hands in different areas == two targets.
Signal to noise ratio. Aka, how ā€œstrongā€ the detection is.
if target is detection motion above a threshold (I just remove noise) but it’s also without motion , I mean staying static ? The noise is to differentiate a static vs motion detection ?
Targets are not link to the number of those antenna patches ? Because patch on top will trigger another area then patch below ?
People still ā€œmove a little while staticā€ that’s how this works :wink:
[edit] - I think people inherently associate ā€œmovementā€ with ā€œgetting up and walkingā€. But even ā€œstanding/sitting stillā€ (aka, static in relation to walking), you sway a little, you breathe, you twitch…
Perhaps a categorization of, ā€œlevels of movementā€ would be helpful. Perhaps;
  • motion = walking
  • micro-motion = standing in place or sitting
  • nano-motion = laying down / sleeping (aka just your breathing)
What? Antenna patches != targets. The firmware supports the identification of up to eight targets.
I have a 100x100deg module coming and it only has two patches. It has the same firmware options.
Pre-sure micro motion is generally used by companies to refer to sleeping, standing, sitting, all of those you’re more or less just breathing.
Darn companies :stuck_out_tongue_winking_eye:
I’ll need to differentiate in the upcoming mmWave sensor showdown!
I am still experimenting with SNR, but one possible use-case is ā€œa close target w/ weak SNR could indicate a catā€ type of idea…
OP updated including cleaner lambda code from @phillip1
@crlogic Would you mind double-checking your posted ESPHome code? I’m compiling it for my D1 Mini but the text sensor part is throwing the following errors:
'text_sensors' is a required option for [text_sensor.custom]
and on the next line:
lambda doesn't contain a return statement, but the lambda is expected to return a value. Please make sure the lambda contains at least one return statement
It would also be worth highlighting (for newbies like me!) the new requirement to include the UART text sensor in the esphome folder as per Custom UART Text Sensor — ESPHome
Good catch. So many changes lately my eye get crossed!
I’ll double check the whole thing later, just added the following;
text_sensor:
  - platform: custom
    lambda: |-
      auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
      App.register_component(my_custom_sensor);
      return {my_custom_sensor};
    text_sensors:
      internal: true
      on_value:
        lambda: |-
          std::string line = id(uart_readline).state;
          if (id(uart_target_output_$shortname).state && line.substr(0, 6) == "$JYRPO")
              auto publishTarget = [](std::string idx, float dist, float snr) {
                  auto sens = App.get_sensors();
                  for(int i = 0; i < sens.size(); i++) {
                    auto name = sens[i]->get_name();
                    auto target = "target_" + to_string(idx);
                    if(name.size() > 10 && name.substr(0, 8) == target) {
                      if(name.substr(9, 3) == "dis") {
                        sens[i]->publish_state(dist);
                      } else if(name.substr(9, 3) == "SNR") {
                        sens[i]->publish_state(snr);
              line = line.substr(6);
              std::vector<std::string> v;
              for(int i = 0; i < line.length(); i++) {
                  if(line[i] == ',') {
                      v.push_back("");
                  } else {
                      v.back() += line[i];
              id(num_targets).publish_state(parse_number<float>(v[0]).value());
              publishTarget(v[1], parse_number<float>(v[2]).value(), parse_number<float>(v[4]).value());
              for(int i = parse_number<int>(v[0]).value() +1 ; i < 9; i++) publishTarget(to_string(i), 0, 0);
Thanks for the fast response! It will now start compiling but then aborts with error 1 after this:
/config/esphome/occupancy.yaml:391:14: error: 'uart_target_output_$shortname' was not declared in this scope
  391 |           if (id(uart_target_output_$shortname).state && line.substr(0, 6) == "$JYRPO")```
Yeah my bad; distracted. Remove this. I have three versions going and watching qualifying!!
[A call for testers]
Need some help, the next update is a stretch project for me. I am looking for a small number of testers who are comfortable making breaking changes, potential crashes, and can perform direct serial re-flash if needed.
I have started bumbling my way through a Custom Sensor Component. The goals include;
  • led/distance/latency/sensitivity state queries from the MCU function as expected
    ** these occur on_boot, on_value, and when factory_reset_sensor_config are used
Other changes include:
  • reduced unneeded switches
  • target tracking is now default behavior
Caveats of my first custom component:
  • hard-coded entity names in the .h means you cannot change any id
Hey, just thought I’d share my setup:
Quite pleased with the way it’s turned out, my own version of an FP1!
Like others I used a D1 mini as my base. I also included a BH1750 lux sensor so I can automate my lights based on ambient light levels - the body lets in enough light for it to take useful measurements.
One slight issue is that it currently will pick up movement in the hallway through the wall you can see to the right of the device in the picture. Dialling down sensitivity unfortunately makes it less useful at picking up distant motion in the room itself. Any ideas on how to prevent it from looking into the hallway?
@crlogic - I have made some tweaks to your code to better utilise substitutions so that if someone wants to set up more than one of these then all the buttons/sensors/switches are easier to differentiate in HA. Also some minor tweaks to units of measurement:
esphome:
  includes:
    - uart_read_line_sensor.h
esp8266:
  board: d1_mini #change as needed
# Enable logging
logger:
  logs:
    text_sensor: INFO
    sensor: INFO
substitutions:
  device_name: living_room_presence #change as needed
  device_friendly_name: Living Room Presence #change as needed
# Enable Home Assistant API
api:
  services:
      # Service to send a command directly to the display. Useful for testing
    - service: send_command
      variables:
        cmd: string
      then:
        - uart.write: !lambda
            std::string command = to_string(cmd) +"\r";
            return std::vector<uint8_t>(command.begin(), command.end());
ota:
  password: #snip
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Living Room Presence Hotspot"
    password: #snip
captive_portal:
uart:
  tx_pin: D2
  rx_pin: D1
  baud_rate: 115200
web_server:
  port: 80
  version: 2
  include_internal: true
  ota: false
http_request:
  useragent: esphome/$device_name
  timeout: 2s
binary_sensor:
  - platform: gpio
    pin:
      number: D0 #change as needed
      mode: INPUT_PULLDOWN
    on_state:
     - if:
        condition:
          - binary_sensor.is_off: $device_name
        then:
          - sensor.template.publish:
              state: 0.0
              state: 0.0
              state: 0.0
    name: ${device_friendly_name} Target 1 Distance
    unit_of_measurement: m
    internal: true
    name: ${device_friendly_name} Target 2 Distance
    internal: true
    name: ${device_friendly_name} Target 3 Distance
    internal: true
    name: ${device_friendly_name} Target 4 Distance
    internal: true
    name: ${device_friendly_name} Target 5 Distance
    internal: true
    name: ${device_friendly_name} Target 6 Distance
    internal: true
    name: ${device_friendly_name} Target 7 Distance
    internal: true
    name: ${device_friendly_name} Target 8 Distance
    internal: true
    name: ${device_friendly_name} Target 1 SNR
    internal: true
    name: ${device_friendly_name} Target 2 SNR
    internal: true
    name: ${device_friendly_name} Target 3 SNR
    internal: true
    name: ${device_friendly_name} Target 4 SNR
    internal: true
    name: ${device_friendly_name} Target 5 SNR
    internal: true
    name: ${device_friendly_name} Target 6 SNR
    internal: true
    name: ${device_friendly_name} Target 7 SNR
    internal: true
    name: ${device_friendly_name} Target 8 SNR
    internal: true
  - platform: bh1750 #ignore if not using a bh1750 lux sensor
    address: 0x23
    update_interval: 60s
switch:
  - platform: safe_mode
    name: ${device_friendly_name} Safe Mode
    entity_category: diagnostic
    name: ${device_friendly_name} mmWave Sensor
    entity_category: config
    optimistic: true
    restore_state: true
    assumed_state: true
    turn_on_action:
      - uart.write: "sensorStart"
    turn_off_action:
      - uart.write: "sensorStop"
    optimistic: true
    restore_state: true
    assumed_state: true
    turn_on_action:
      - switch.turn_off: ${device_name}_mmwave_sensor
      - delay: 1s
      - uart.write: "setLedMode 1 0"
      - delay: 1s
      - uart.write: "saveConfig"
      - delay: 3s
      - switch.turn_on: ${device_name}_mmwave_sensor
      - delay: 1s
    turn_off_action:
      - delay: 1s
      - uart.write: "setLedMode 1 1"
      - delay: 1s
      - delay: 3s
      - delay: 1s
    name: ${device_friendly_name} UART Presence Output
    optimistic: true
    restore_state: true
    assumed_state: true
    turn_on_action:
      - delay: 1s
      - uart.write: "setUartOutput 1 1"
      - delay: 1s
      - delay: 3s
      - delay: 1s
    turn_off_action:
      - delay: 1s
      - uart.write: "setUartOutput 1 0"
      - delay: 1s
      - delay: 3s
      - delay: 1s
    name: ${device_friendly_name} UART Target Output
    optimistic: true
    restore_state: true
    assumed_state: false
    turn_on_action:
      - delay: 1s
      - uart.write: "setUartOutput 2 1 1 1"
      - delay: 1s
      - delay: 3s
      - delay: 1s
    turn_off_action:
      - delay: 1s
      - uart.write: "setUartOutput 2 0"
      - delay: 1s
      - delay: 3s
      - delay: 1s
number:
    min_value: 0.15
    max_value: 9.45
    initial_value: 3.15
    optimistic: true
    step: 0.15
    restore_value: true
    mode: box
    set_action:
      - delay: 1s
                      std::string range = "setRange 0 " + str_sprintf("%.2f", x);
                      return std::vector<unsigned char>(range.begin(), range.end());
      - delay: 1s
      - delay: 1s
      - delay: 1s
    min_value: 1
    max_value: 600
    initial_value: 90
    optimistic: true
    step: 1
    restore_value: true
    unit_of_measurement: s
    mode: box
    set_action:
      - delay: 1s
                      std::string setL = "setLatency 0.1 " + str_sprintf("%.0f", x);
                      return std::vector<unsigned char>(setL.begin(), setL.end());
      - delay: 1s
      - delay: 1s
    name: ${device_friendly_name} Sensitivity
    min_value: 0
    max_value: 9
    initial_value: 9
    optimistic: true
    step: 1
    restore_value: true
    set_action:
      - delay: 1s
                      std::string mss = "setSensitivity " + to_string((int)x);
                      return std::vector<unsigned char>(mss.begin(), mss.end());
      - delay: 1s
      - delay: 1s
button:
  - platform: restart
    name: ${device_friendly_name} Update Sensitivity
    internal: true
    on_press:
                      std::string getS = "getSensitivity";
                      return std::vector<unsigned char>(getS.begin(), getS.end());
    name: ${device_friendly_name} Update Latency
    internal: true
    on_press:
                      std::string getL = "getLatency";
                      return std::vector<unsigned char>(getL.begin(), getL.end());
    name: ${device_friendly_name} Update Range
    internal: true
    on_press:
                      std::string getR = "getRange";
                      return std::vector<unsigned char>(getR.begin(), getR.end());
    name: ${device_friendly_name} Factory Reset
    on_press:
      - delay: 1s
      - uart.write: "resetCfg"
      - delay: 3s
text_sensor:
  - platform: custom
    lambda: |-
    text_sensors:
      name: ${device_friendly_name} UART Output
      internal: true
      on_value:
        lambda: |-
          if (id(${device_name}_uart_target_output).state && line.substr(0, 6) == "$JYRPO")
                      v.push_back("");
                  } else {
              id(${device_name}_num_targets).publish_state(parse_number<float>(v[0]).value());
i2c: #ignore if not using an i2c bus (in my case for the bh1750)
  sda: D6
  scl: D7
  scan: true
Have you noticed device crashing when target tracking is on? I need to test further but seem to be finding that my setup went through a number of unexpected reboots when both target tracking and UART output were on whilst I was debugging range and sensitivity
Sensitivity != distance :wink:
I have recently updated the OP with better tuning descriptions.
That looks very nice! Well done.
I would caution against changing id: as it will be more important in upcoming revisions. name: is fine and can be changed to taste. I will be sure to better highlight this in the future.
