Releasing a beta version of the code that offers led, distance, latency and sensitivity setting synchronization that earlier versions lacked. I am leaving uart debugging enabled in order to better understand any issues one may have.
Having run this version all week it runs as stable as the OP with the same constraint that leaving a browser sitting open refreshing the web_server will quickly allow an ESP32 to run out of resources and reboot. Therefore the same warning applies; use the web_server for tuning and not a dashboard.
This version is not recommended unless you have a stable working deployment and have the ability to troubleshoot compilation, perform uart debugging and wired re-flashing if necessary.
A custom .h file is required
uart_read_line_sensor_leapmmw.h
#include "esphome.h"
#include <string>
void publishTarget(std::string idx, float dist, float snr) {
auto get_sensors = App.get_sensors();
for(int i = 0; i < get_sensors.size(); i++) {
auto name = get_sensors[i]->get_name();
auto target = "target_" + to_string(idx);
if(name.size() > 10 && name.substr(0, 8) == target) {
if(name.substr(9, 3) == "dis") {
get_sensors[i]->publish_state(dist);
} else if(name.substr(9, 3) == "SNR") {
get_sensors[i]->publish_state(snr);
static void clearTargets () {
for(int i = 1 ; i < 9; i++) publishTarget(to_string(i), 0, 0);
class leapmmw : public Component, public UARTDevice {
public:
leapmmw(UARTComponent *parent) : UARTDevice(parent) {}
void setup() override {
void publishNumber (std::string sensor, float resp) {
auto get_numbers = App.get_numbers();
for(int i = 0; i < get_numbers.size(); i++) {
auto name = get_numbers[i]->get_name();
if(name.size() > 6 && name == sensor) {
get_numbers[i]->publish_state(resp);
void publishSwitch(std::string sensor, int state) {
auto sens = App.get_switches();
for(int i = 0; i < sens.size(); i++) {
auto name = sens[i]->get_name();
if(name.size() > 2 && name == sensor) {
sens[i]->publish_state(state);
void getmmwConf(std::string mmwparam) {
write_array(std::vector<unsigned char>(mmwparam.begin(), mmwparam.end()));
int readline(int readch, char *buffer, int len)
static int pos = 0;
int rpos;
if (readch > 0) {
switch (readch) {
case '\n': // Ignore new-lines
break;
case '\r': // Return on CR
rpos = pos;
pos = 0; // Reset position index ready for next time
return rpos;
default:
if (pos < len-1) {
buffer[pos++] = readch;
buffer[pos] = 0;
// No end of line has been found, so return -1.
return -1;
std::string getline;
void loop() override {
const int max_line_length = 40;
static char buffer[max_line_length];
while (available()) {
if (id(mmwave_sensor).state == 0 && id(num_targets).state > 0) {
id(num_targets).publish_state(0);
clearTargets();
if(readline(read(), buffer, max_line_length) >= 4) {
std::string line = buffer;
if (line.substr(0, 18) == "leapMMW:/>$JYBSS,0" && id(num_targets).state > 0) {
clearTargets();
if (line.substr(0, 6) == "$JYRPO") {
std::string vline = line.substr(6);
std::vector<std::string> v;
for(int i = 0; i < vline.length(); i++) {
if(vline[i] == ',') {
v.push_back("");
} else {
v.back() += vline[i];
id(num_targets).publish_state(parse_number<float>(v[0]).value());
publishTarget(v[1], parse_number<float>(v[2]).value(), parse_number<float>(v[4]).value());
for(int i = parse_number<int>(v[0]).value() +1 ; i < 9; i++) publishTarget(to_string(i), 0, 0);
if (line.substr(0, 6) == "$JYRPO" && id(mmwave_sensor).state == 0) {
publishSwitch("mmwave_sensor", 1);
// compare last line
if (line.substr(0, 8) == "Response") {
ESP_LOGD("custom", "Found Response - line is: %s", line.c_str());
ESP_LOGD("custom", "Found Response - lastline is: %s", getline.c_str());
// leapMMW:/>getSensitivity
if (getline.substr(0, 24) == "leapMMW:/>getSensitivity") {
std::string getSensitivity = line.substr(9, 1);
if (getSensitivity.empty()) {
ESP_LOGD("custom", "Did not find a value for getSensitivity");
} else {
ESP_LOGD("custom", "The value of getSensitivity is: %f", parse_number<float>(getSensitivity).value());
publishNumber("sensitivity", parse_number<float>(getSensitivity).value());
// leapMMW:/>getRange
if (getline.substr(0, 18) == "leapMMW:/>getRange") {
std::string getRange = line.substr(15, 5);
if (getRange.empty()) {
ESP_LOGD("custom", "Did not find a value for getRange");
} else {
ESP_LOGD("custom", "The value of getRange is: %f", parse_number<float>(getRange).value());
publishNumber("distance", parse_number<float>(getRange).value());
// leapMMW:/>getLatency
if (getline.substr(0, 20) == "leapMMW:/>getLatency") {
std::string getLatency = line.substr(15, 3);
if (getLatency.empty()) {
ESP_LOGD("custom", "Did not find a value for getLatency");
} else {
ESP_LOGD("custom", "The value of getLatency is: %f", parse_number<float>(getLatency).value());
publishNumber("latency", parse_number<float>(getLatency).value());
// leapMMW:/>getLedMode
if (getline.substr(0, 20) == "leapMMW:/>getLedMode") {
std::string getLedMode = line.substr(11, 1);
if (getLedMode.empty()) {
ESP_LOGD("custom", "Did not find a value for getLedMode");
} else {
int led_state = parse_number<int>(getLedMode).value();
ESP_LOGD("custom", "The value of getLedMode is: %i", led_state);
int setled_state;
if (led_state == 1) {
setled_state = 0;
} else if (led_state == 0) {
setled_state = 1;
publishSwitch("led", setled_state);
if (line.substr(0, 4) == "Done") {
ESP_LOGD("custom", "Found Done - line is: %s", line.c_str());
ESP_LOGD("custom", "Found Done - lastline is: %s", getline.c_str());
// leapMMW:/>sensorStop
if (getline.substr(0, 20) == "leapMMW:/>sensorStop") {
ESP_LOGD("custom", "sensorStop completed successfully");
publishSwitch("mmwave_sensor", 0);
// leapMMW:/>sensorStart
if (getline.substr(0, 21) == "leapMMW:/>sensorStart") {
ESP_LOGD("custom", "sensorStart completed successfully");
getline = buffer;
Beta YAML
esphome:
platform: ESP32
board: esp32dev
includes:
- uart_read_line_sensor_leapmmw.h
on_boot:
priority: -100
then:
- script.execute: get_mmwave_params # still needed with getmmwConf()
# Enable logging
logger:
logs:
sensor: INFO # DEBUG level with uart_target_output = overload!
text_sensor: INFO
# Enable Home Assistant API
api:
reboot_timeout: 6h
services:
# Service to send a command directly to the display. Useful for testing
- service: send_command
variables:
cmd: string
then:
- uart.write: !lambda
std::string command = to_string(cmd) +"\r";
return std::vector<uint8_t>(command.begin(), command.end());
ota:
password: !secret ota
wifi:
ssid: !secret wifi_ssid
ap:
ssid: !secret ap_ssid
password: !secret ap_password
substitutions:
device_name: mmwave-extra
web_server:
port: 80
version: 2
include_internal: true
ota: false
http_request:
useragent: esphome/$device_name
timeout: 2s
captive_portal:
uart:
tx_pin: GPIO19
rx_pin: GPIO23
baud_rate: 115200
debug:
direction: BOTH
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
binary_sensor:
- platform: gpio
pin:
number: GPIO18
mode: INPUT_PULLDOWN
on_state:
- if:
condition:
binary_sensor.is_off: mmwave_presence_detection
then:
- sensor.template.publish:
state: 0
- lambda: |-
return clearTargets();
- platform: uptime
update_interval: 60s
internal: true
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days)+":" : "00:") +
(hours ? to_string(hours)+":" : "00:") +
(minutes ? to_string(minutes)+":" : "00:") +
(to_string(seconds))
).c_str();
id: target_1_distance_m # do not change
internal: true
id: target_2_distance_m # do not change
internal: true
id: target_3_distance_m # do not change
internal: true
id: target_4_distance_m # do not change
internal: true
# - platform: template
# name: target_5_distance_m
# id: target_5_distance_m # do not change
# internal: true
# name: target_6_distance_m
# id: target_6_distance_m # do not change
# internal: true
# name: target_7_distance_m
# id: target_7_distance_m # do not change
# internal: true
# name: target_8_distance_m
# id: target_8_distance_m # do not change
# internal: true
id: target_1_SNR # do not change
internal: true
id: target_2_SNR # do not change
internal: true
id: target_3_SNR # do not change
internal: true
id: target_4_SNR # do not change
internal: true
# name: target_5_SNR
# id: target_5_SNR # do not change
# internal: true
# name: target_6_SNR
# id: target_6_SNR # do not change
# internal: true
# name: target_7_SNR
# id: target_7_SNR # do not change
# internal: true
# name: target_8_SNR
# id: target_8_SNR # do not change
# internal: true
id: num_targets # do not change
- platform: custom
lambda: |-
auto s = new leapmmw(id(uart_bus));
App.register_component(s);
return {};
sensors:
switch:
- platform: safe_mode
id: mmwave_sensor # do not change
entity_category: config
optimistic: true
# assumed_state: true
turn_on_action:
- uart.write: "setUartOutput 1 0"
- delay: 1s
- uart.write: "setUartOutput 2 1 1 2"
- delay: 1s
- uart.write: "saveConfig"
- delay: 3s
- uart.write: "sensorStart"
# - delay: 3s
# - script.execute: get_mmwave_params # not needed with getmmwConf
turn_off_action:
- uart.write: "sensorStop"
id: led # do not change
optimistic: true
turn_on_action:
- switch.turn_off: mmwave_sensor
- delay: 1s
- uart.write: "setLedMode 1 0"
- delay: 1s
- lambda: |-
leapmmw(id(uart_bus)).getmmwConf("getLedMode 1");
- delay: 1s
- switch.turn_on: mmwave_sensor
turn_off_action:
- delay: 1s
- uart.write: "setLedMode 1 1"
- delay: 1s
- lambda: |-
- delay: 1s
number:
id: distance # do not change
min_value: 0.15
max_value: 9.45
initial_value: 6
optimistic: true
step: 0.15
unit_of_measurement: M
mode: box
# lambda: |-
# return leapmmw(id(uart_bus)).getmmwConf("getRange");
set_action:
- delay: 1s
std::string range = "setRange 0 " + str_sprintf("%.2f", x);
return std::vector<unsigned char>(range.begin(), range.end());
- delay: 1s
- lambda: |-
- delay: 1s
id: latency # do not change
min_value: 1
max_value: 600
initial_value: 15
optimistic: true
# lambda: |-
# return leapmmw(id(uart_bus)).getmmwConf("getLatency");
step: 1
unit_of_measurement: s
mode: box
set_action:
- delay: 1s
std::string setL = "setLatency 0.1 " + str_sprintf("%.0f", x);
return std::vector<unsigned char>(setL.begin(), setL.end());
- delay: 1s
- lambda: |-
- delay: 1s
id: sensitivity # do not change
min_value: 0
max_value: 9
initial_value: 7
optimistic: true
# lambda: |-
# return leapmmw(id(uart_bus)).getmmwConf("getSensitivity");
step: 1
set_action:
- delay: 1s
std::string mss = "setSensitivity " + to_string((int)x);
return std::vector<unsigned char>(mss.begin(), mss.end());
- delay: 1s
- lambda: |-
- delay: 1s
button:
- platform: restart
entity_category: diagnostic
on_press:
- uart.write:
data: "resetSystem 0"
on_press:
- delay: 1s
- uart.write: "resetCfg"
- delay: 3s
script:
- id: get_mmwave_params
then:
- uart.write: "getLedMode 1"
- delay: 1s
- uart.write: "getRange"
- delay: 1s
- uart.write: "getLatency"
- delay: 1s
- uart.write: "getSensitivity"
