Works exactly the same as the other LD2410 variants, basically a different form factor (IMO a better one). Used the same code for both sensors, but have not tested side by side, since I ran out of ESP dev boards
Dont know if it supports BT, as I can’t install the app on my phone.
Yup! Got mine too
Each get
command “reads” that specific part of the config.
[edit] I think there may have been some confusion here between read
literal and read the verb/action/intention.
You can, “read the config” using the provided get
commands.
You cannot readConfig
as that is not the literal command to type in order to do so.
I recently got a DFRobot mmWave and noticed it’s detecting me on the back of the sensor too (at a shorter distance) but this doesn’t seem to happen with my mmWave sensors from LeapmmWave (the original manufacturer)… do you guys have same experience or is my sensor defective?
hello! i have very specific question to ask , i was watching everything smart home (this video Building My Perfect Smart Home Presence Detection Sensor! - YouTube) and he used this code and stuff to get his mmwave sensor working and im trying to do the same but im confused, the pin-out of the board and the way he soldered it out shouldn’t work but his does, he put the sensor in i022, i021, i017, i016, and of course GND and VCC (5v) but on the df robot page it says you need the rx and tx to be plugged in, im wondering how i can do the same as him and get my sensor working, i hope someone can help because im at a loss, i wish he could have shown the install of the code
The ESP32 can do serial RX/TX on other pins as well. In fact the pins RX/TX are normally connected to the USB to serial chip and used to flash the ESP32 via USB
So how would I put it in the code? Would I put it as i022 and i021?
Yes just put the PIN number, if it doesn’t work switch them
yeah i posted about it on a different thread and got some help but i get this after the install and i get no detection data
nvm i fixed it had to change the gpio pin to 17 and that did the trick
looks like a perfect case. What are the dimensions inside? would a esp32 d1 mini fit inside? also is the base hollow? it its hollow I´m thinking I could add a temp sensor there, perfect spot, below the esp32 so the heat from the board would not affect it.
Hi, I have a little problem with the esp8266 mini d1 and the SEN0395. it works fine, but after few updates, the blue light on the d1 turn on and will not boot, its like is stuck in boot-loader. If I re-flash it ad remove the code from number then works fine, but I cant configure it. If I flash the code to a new esp8266 then it works fine, but again, because I’m trying different sensors and configurations, after few flashes, again. I also included a bme680 and bh1750.
My code is bellow. any help how I can get around this problem, I have 2 boards that I can only use if I remove the code from number to bme680_bsec.
esphome:
platform: ESP8266
board: d1_mini
# Insert your SSID and Your PWD after inital setup
wifi:
ssid: "WIFI SSID"
password: "WIFI PASSWORD"
manual_ip:
static_ip: 192.168.0.106
gateway: 192.168.0.1
subnet: 255.255.255.0
ap:
ssid: ${name}
password: "12345678"
# Enable logging
logger:
# Enable Home Assistant API
api:
# Enable Home Assistant OTA Updates
ota:
password: ""
# Enable the captive portal for inital WiFi setup
captive_portal:
substitutions:
friendly_name: Sensors Eli Room
room: "Eli"
uart:
tx_pin: GPIO3
rx_pin: GPIO1
baud_rate: 115200
debug:
direction: BOTH
dummy_receiver: true
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
i2c:
- id: bus_a
sda: D2
scl: D1
scan: True
web_server:
port: 80
version: 2
include_internal: true
http_request:
useragent: esphome/$name
timeout: 2s
binary_sensor:
- platform: gpio
device_class: occupancy
pin:
number: GPIO16
mode: INPUT_PULLDOWN
- platform: status
switch:
- platform: gpio
pin: GPIO2
inverted: true
icon: "mdi:lightbulb"
name: "mmWave Sensor ${name}"
optimistic: true
restore_state: true
turn_on_action:
- uart.write: "sensorStart"
- delay: 1s
turn_off_action:
- uart.write: "sensorStop"
- delay: 1s
name: "mmWave LED ${name}"
optimistic: true
restore_state: true
assumed_state: false
turn_on_action:
- switch.turn_off: mmwave_sensor
- delay: 1s
- uart.write: "setLedMode 1 0"
- delay: 1s
- uart.write: "saveConfig"
- delay: 3s
- switch.turn_on: mmwave_sensor
turn_off_action:
- delay: 1s
- uart.write: "setLedMode 1 1"
- delay: 1s
- delay: 3s
number:
min_value: 0
max_value: 800
initial_value: 315
optimistic: true
step: 15
restore_value: true
unit_of_measurement: cm
mode: box
set_action:
- delay: 1s
- uart.write: !lambda int cm = (int)ceil(x / 15.0);
std::string cms = "detRangeCfg -1 0 " + to_string(cm);
return std::vector<unsigned char>(cms.begin(), cms.end());
- delay: 1s
- uart.write: "saveCfg 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
- delay: 1s
name: mmWave Off Latency
min_value: 0
max_value: 65000
initial_value: 12500
optimistic: true
step: 25
restore_value: true
unit_of_measurement: ms
mode: box
set_action:
- delay: 1s
int ms = (int)ceil(x / 25.0);
std::string mss = "outputLatency -1 0 " + to_string(ms);
return std::vector<unsigned char>(mss.begin(), mss.end());
- delay: 1s
- delay: 1s
name: mmWave Sensitivity
min_value: 0
max_value: 9
initial_value: 7
optimistic: true
step: 1
restore_value: false
set_action:
- delay: 1s
- uart.write:
!lambda std::string mss = "setSensitivity " + to_string((int)x);
- delay: 1s
- delay: 1s
bme680_bsec:
# i2c address override (default is 0x76)
address: 0x77
# Temperature offset
# Useful if device is in enclosure and reads too high
# For example if it reads 5C too high, set this to 5
# This also corrects the relative humidity readings
# Default: 0
temperature_offset: 2.0
# IAQ calculation mode
# Available options:
# - static (for fixed position devices)
# - mobile (for on person or other moveable devices)
# Default: static
iaq_mode: static
# Interval at which to save BSEC state (default is 6 hours)
state_save_interval: 6h
# Sample rate
# - lp (low power - samples every 3 seconds)
# - ulp (ultra low power - samples every 5 minutes)
# Default: lp
sample_rate: lp
- platform: bh1750
# Illuminance level in lux from BH1750
address: 0x23
update_interval: 30s
- platform: bme680_bsec
temperature:
# Temperature in °C from BME680
sample_rate: lp
filters:
- median
- offset: -1.6
pressure:
# Pressure in hPa from BME680
name: "Air Pressure ${name}"
sample_rate: lp
unit_of_measurement: "hPa"
filters:
- lambda: >-
return x / powf(1.0 - (415 / 44330.0), 5.255);
humidity:
# Relative humidity % from BME680
sample_rate: lp
filters:
- median
- offset: 13.0
gas_resistance:
# Gas resistance in Ω from BME680
name: "CO2 resistance ${name}"
filters:
- median
iaq:
# Indoor air quality value from BME680
filters:
- median
co2_equivalent:
# CO2 equivalent estimate in ppm from BME680
name: "CO2 Equivalent ${name}"
filters:
- median
breath_voc_equivalent:
# Volatile organic compounds equivalent estimate in ppm from BME680
name: "Breath VOC Equivalent ${name}"
filters:
- median
iaq_accuracy:
# IAQ accuracy as a numeric value of 0, 1, 2, 3 from BME680
name: "Numeric IAQ Accuracy ${name}"
- platform: uptime
update_interval: 60s
- platform: wifi_signal
# Absolute humidity in g/m³ based on himidity from BME680
name: "Absolute humidity ${name}"
lambda: |-
const float mw = 18.01534; // molar mass of water g/mol
const float r = 8.31447215; // Universal gas constant J/mol/K
return (6.112 * powf(2.718281828, (17.67 * id(temp).state) /
(id(temp).state + 243.5)) * id(humidity).state * mw) /
((273.15 + id(temp).state) * r); // in grams/m^3
accuracy_decimals: 2
icon: 'mdi:water'
unit_of_measurement: 'g/m³'
name: "Air pressure at sea level ${name}"
lambda: |-
const float STANDARD_ALTITUDE = 415; // in meters, see note
return id(pressure).state / powf(1 - ((0.0065 * STANDARD_ALTITUDE) /
(id(temp).state + (0.0065 * STANDARD_ALTITUDE) + 273.15)), 5.257); // in hPa
unit_of_measurement: 'hPa'
name: "Dew point ${name}"
lambda: return (243.5*(log(id(humidity).state/100)+((17.67*id(temp).state)/
(243.5+id(temp).state)))/(17.67-log(id(humidity).state/100)-
((17.67*id(temp).state)/(243.5+id(temp).state))));
unit_of_measurement: '°C'
# bme680_sec
iaq_accuracy:
name: "IAQ Accuracy ${name}"
text_sensor:
name: "Air quality ${name}"
icon: "mdi:air-filter"
lambda: |-
ESP_LOGD("main", "Current value %d", id(iaq_range));
if ((id(iaq_range).state <= 50.0 )) {
return {"Very good"};
else if ((id(iaq_range).state > 50.00) && (id(iaq_range).state <= 100.0)) {
return {"Good"};
else if ((id(iaq_range).state > 100.0) && (id(iaq_range).state <= 150.0)) {
return {"A little dirty"};
else if ((id(iaq_range).state > 150.0) && (id(iaq_range).state <= 200.0)) {
return {"Moderately dirty"};
else if ((id(iaq_range).state > 200.0) && (id(iaq_range).state <= 250.0)) {
return {"Very dirty"};
else if ((id(iaq_range).state > 250.0) && (id(iaq_range).state <= 350.0)) {
return {"Extremely dirty"};
else if ((id(iaq_range).state > 350.00)) {
return {"Dangerously polluted"};
return {};
- platform: wifi_info
ip_address:
ssid:
bssid:
mac_address:
name: ESP Board Mac Address
time:
- platform: homeassistant
Standard troubleshooting procedures apply; use a systematic approach.
I would personally remove everything, add one thing at a time and run for a week to prove that in isolation, all things before it work.
The 8266 is pretty underpowered compared to a 32 and the webserver & debug can add quite a bit of load/memory_consumption based on my experience. Don’t add what isn’t 100% necessary.
I tried, even if I remove everything but the mmwave still the same unless I delete the latency, sensibility and distance.
Have you tested restore_value: false
I tried with optimistic: true, optimistic: false, restore_value: true, restore_value: false also removing the 2 values
Have you tested with nothing but a ‘dummy’ number:
configuration?
Eg.
number:
min_value: 0
max_value: 800
initial_value: 315
optimistic: true
step: 15
restore_value: true
mode: box
with one dummy number works, thank you for the idea. I then created 4 dummy numbers, works fine, I then remove all and added only one, tried the 3 numbers mmwave_latency, mmwave_sensitivity and then the mmWave Distance, with any of the 3 fails. if I remove the code then doesn’t get stuck
- delay: 1s
- delay: 1s
