mmWave Presence Detection - ESPHome style
adding the line - uart.write: “saveConfig” , is when it fails
If I use it like bellow, works, and visiting the page of the esp, the value changes, but I think it actually writes the value, is just for show.
number:
    min_value: 0
    max_value: 800
    initial_value: 315
    optimistic: true
    step: 15
    restore_value: False
    unit_of_measurement: cm
    mode: box
    set_action:
      - switch.turn_off: mmwave_sensor
      - delay: 1s
      - uart.write: !lambda int cm = (int)ceil(x / 15.0);
                      std::string cms = "detRangeCfg -1 0 " + to_string(cm);
                      return std::vector<unsigned char>(cms.begin(), cms.end());
      - delay: 1s
      - switch.turn_on: mmwave_sensor
removing the line bellow, no error.
      - uart.write: "saveCfg 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
Pretty old code. Without saving the changes, a reboot of the mmWave will revert to saved values.
Try, - uart.write: "saveConfig"
with the - uart.write: “saveConfig” it doesnt boot. I did found anothe code, I guess I have ti adapt it to mine
Replace
number:
    min_value: 0
    max_value: 800
    initial_value: 315
    optimistic: true
    step: 15
    restore_value: true
    mode: box
    set_action:
      - delay: 1s
      - delay: 1s
      - delay: 1s
WITH
number:
    id: distance # do not change
    entity_category: config
    min_value: 0.15
    max_value: 9.45
    step: 0.15
    unit_of_measurement: M
    mode: box
    lambda: |-
      leapmmw(id(uart_bus)).getmmwConf("getRange");
      return {};
    set_action:
      - delay: 2s
          std::string range = "setRange 0 " + str_sprintf("%.2f", x);
          return std::vector<unsigned char>(range.begin(), range.end());
      - delay: 3s
You are the only report of this symptom, suspect you have a wonky ESP('s).
Without saving the setting the sensor will revert on any sensor reboot. Dunno why you are re-inventing the wheel.
i, m not trying to reinvent the wheel, just understand why the ESP8266 will stop working after few flashes. Like I said, with a new esp8266 works fine, until eventually dies again. I already have 2 boards, with the same problem
Have you tried two ESP32’s? Have you tried two different brand of ESP8266’s? Are the ones you have from the same manufacturing batch? Have you reverted to an ESPHome version before recent changes to saving PSRAM? Have you tried different power supplies?
Removing saveConfig is not the end solution here. It is mandatory to ensure the setting the “ESP tells you is in use” is the “setting the sensor has saved which ensures it is actually in use.”
esp32 works fine, I have few boards, and no problem in any, the esp8266 I tries D1 mini V4 usb c, d1 mini v3 usb C and a regular d1 mini mini usb. On the regular one I removed the shield and it have a ESP8266EX, some sort of bios chip, a crystal, few resistors, and few capacitors, cant see any branding. They from Ali express, from different sellers. maybe I should get better boards.
I can only vouch for running this on ESP32’s so your mileage will definitely vary.
Nice to read that you got it to work. But it is not clear to me how. You write “switched off the LED” like it’s obvious but how did you switch it off?
(I have my TX → RX and RX → TX right)
Thank you. Got it working. changing the logger to level: none, works, with all the numbers and sensors. If the logger is none will the uart values are still written to the 8266?
I see it now, ha.
hardware_uart (Optional, string): The Hardware UART to use for logging. Defaults to UART0.
seems like it now can be integrated standalone by bluetooth LD2410 BLE - Home Assistant
Where have u seen discussion that the upcoming Aqara is using a sensor from Acconeer? About the angel, It is 65 in horizontal and 53 in vertical. So if it is an a121, then it might be 2 sensors?
That 3d printed case looks like exactly the kind of thing I’m looking for. Would you be willing to share the source for it?
It has a few issues I was going to fix but never got around to it as I designed a new one with different parts instead. Do you want to install it in the wall? It’s a tight fit to get it acually installed is the main issue but it does work. I uploaded the files here: Printables
Hello Thank You very much for sharing your knowledge :slight_smile:
I try to use this code
substitutions:
  # change device name to match your desired name
  device_name: smmwave
  # change sensor name below to the one you want to see in Home Assistant
  device_name_pretty: Bureau Occupancy Sensor
  # UART Pin configured for a D1 Mini stacked setup
  uart_tx_pin: TX
  # This will vary based on your board
  uart_rx_pin: RX
  gpio_pin: D0
  # (Optional) Path to the leapmmw_sensor.h file relative to your esphome configuration directory.
  header_file: leapmmw_sensor.h
# include the yml file with the sensor configuration
packages:
  inclusions: !include packages/leapmmw_sensor.yml
esphome:
  friendly_name: ESPHome Web b6084c
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "Bhi/N4kTW12duvgnoa3YIbiVQgH9MLsyFThNixFFUWQ="
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-B6084C"
    password: "IVahUg0NXY67"
captive_portal:
web_server:
  port: 80
  version: 2
  include_internal: true
http_request:
  useragent: esphome/$device_name
  timeout: 2s
with file copied from here GitHub - hjmcnew/esphome-hs2xx3a-custom-component at release
/ components/hs2xx3a
/ packages
leapmmw_sensor.h
when i try to install I have this error:
INFO Reading configuration /config/esphome-web-b6084c.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-web-b6084c (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- ESPAsyncTCP-esphome @ 1.2.3
|-- ESPAsyncWebServer-esphome @ 2.1.0
|   |-- Hash @ 1.0
|   |-- ESP8266WiFi @ 1.0
|-- DNSServer @ 1.1.1
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.4
|   |-- libsodium @ 1.10018.1
|-- ArduinoJson @ 6.18.5
|-- ESP8266HTTPClient @ 1.2
Compiling .pioenvs/esphome-web-b6084c/src/main.cpp.o
/config/packages/leapmmw_sensor.yml: In lambda function:
/config/packages/leapmmw_sensor.yml:109:14: error: 'clearTargets' was not declared in this scope
  109 |       - lambda: 'return clearTargets();'
/config/packages/leapmmw_sensor.yml:44:14: error: 'clearTargets' was not declared in this scope
   44 |                 return clearTargets();
*** [.pioenvs/esphome-web-b6084c/src/main.cpp.o] Error 1
========================== [FAILED] Took 5.99 seconds ==========================
I have a seeedstudio Human Static Presence Module Lite ( MR24HPC1 ) and was trying to use this code but i cannot compile it because i’m missing the radar.h library, can you help me on where to find this ?
Thank you in advance.
This might have what you need:
Has anyone tried to add a PIR sensor to the mmwave sensor while using the seeed xaio esp32-C3? I programmed one in and it works great. . . .only everything else quite working. Any thoughts? The board isn’t programmed as the correct board, but the pinouts work exactly as I hooked it up and point to the correct pins. I got most of the code from here: XIAO ESP32C3 accesses Home Assistant via ESPHome service | Seeed Studio Wiki . The binary sensor code I got from here: GPIO Binary Sensor — ESPHome . Before I input the Binary Sensor code and got the PIR sensor working all other mmwave sensor info worked in Home Assistant. Since adding the Binary Sensor, none of it works and shows as Unavailable. My yaml code below:
# part 1:
esphome:
  platformio_options:
    board_build.flash_mode: dio
    board_build.mcu: esp32c3
  includes:
  - R24dvd.h
esp32:
  board: esp32-c3-devkitm-1
  variant: esp32c3
  framework:
    type: esp-idf
# Enable logging
logger:
  hardware_uart: USB_SERIAL_JTAG
  level: DEBUG
api:
  encryption:
    key: "Redacted"
ota:
  password: "Redacted"
wifi:
  ap:
    ssid: "Redacted"
#Test code for PIR Sensor
binary_sensor:
  - platform: gpio
    pin: 8
    name: "APIR Motion-Presence"
    device_class: motion
# part 3:
uart:
  baud_rate:  115200
  rx_pin: 5
  tx_pin: 4
select:
    name: "Standard Scene mode"
    icon: mdi:hoop-house
    optimistic: true
    options:
      - "Living room"
      - "Area detection"
      - "Washroom"
      - "Bedroom"
    initial_option: "Living room"
    set_action:
      - logger.log:
            format: "set action option: %s"
            args: ["x.c_str()"]
                  auto index = id(scene_mode).index_of(x);
                  uint8_t value = (uint8_t)index.value() + 1;
                  uint8_t crc = value + 0xB9;
                  return {0x53,0x59,0x05,0x07,0x00,0x01,value,crc,0x54,0x43};
    name: "Standard unmanned time"
    icon: mdi:timeline-clock
    optimistic: true
    options:
      - "None"
      - "10s"
      - "30s"
      - "1min"
      - "2min"
      - "5min"
      - "10min"
      - "30min"
      - "1hour"
    initial_option: "None"
    set_action:
      - logger.log:
            format: "Chosen option: %s"
            args: ["x.c_str()"]
                  auto index = id(unmanned_time).index_of(x);
                  uint8_t value = (uint8_t)index.value();
                  uint8_t crc = value + 0x37;
                  return {0x53,0x59,0x80,0x0a,0x00,0x01,value,crc,0x54,0x43};
    name: "Custom Presence of perception boundary"
    optimistic: true
    options:
      - "0.5m"
      - "1.0m"
      - "1.5m"
      - "2.0m"
      - "2.5m"
      - "3.0m"
      - "3.5m"
      - "4.0m"
      - "4.5m"
      - "5.0m"
    set_action:
      - logger.log:
            args: ["x.c_str()"]
                  uint8_t crc = value + 0xBF;
                  return {0x53,0x59,0x08,0x0a,0x00,0x01,value,crc,0x54,0x43};
    name: "Custom Motion trigger boundary"
    optimistic: true
    options:
      - "0.5m"
      - "1.0m"
      - "1.5m"
      - "2.0m"
      - "2.5m"
      - "3.0m"
      - "3.5m"
      - "4.0m"
      - "4.5m"
      - "5.0m"
    set_action:
      - logger.log:
            args: ["x.c_str()"]
                  uint8_t crc = value + 0xC0;
                  return {0x53,0x59,0x08,0x0b,0x00,0x01,value,crc,0x54,0x43};
number:
    name: "Standard sensitivity"
    icon: mdi:archive-check-outline
    min_value: 0
    max_value: 3
    optimistic: false
    step: 1
    update_interval: 2s
    set_action:
                    uint8_t crc = x + 0xBA;
                    return {0x53,0x59,0x05,0x08,0x00,0x01,(uint8_t)x,crc,0x54,0x43};
    name: "Standard Maximum detectable range of moving target"
    icon: mdi:map-marker-path
    unit_of_measurement: "cm"
    min_value: 0
    max_value: 65536
    step: 500
    set_action:
                    int h_num = (int)x >> 8;
                    int l_num = (int)x & 0xff;
                    int crc = 0xB6 + h_num + l_num;
                    return {0x53,0x59,0x07,0x01,0x00,0x02,(uint8_t)(h_num),(uint8_t)(l_num),(uint8_t)crc,0x54,0x43};
    name: "Standard Maximum detectable range of stationary target"
    min_value: 0
    max_value: 65536
    step: 500
    set_action:
                    int crc = 0xB9 + h_num + l_num;
                    return {0x53,0x59,0x07,0x04,0x00,0x02,(uint8_t)(h_num),(uint8_t)(l_num),(uint8_t)crc,0x54,0x43};
    name: "Custom Judgment threshold exists"
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0xBD + (int)x;
                    return {0x53,0x59,0x08,0x08,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Motion amplitude trigger threshold"
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0xBE + (int)x;
                    return {0x53,0x59,0x08,0x09,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Mode Settings"
    icon: mdi:cog
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0xBB + (int)x;
                    return {0x53,0x59,0x05,0x09,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Mode Settings End"
    icon: mdi:cog
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0xBC + (int)x;
                    return {0x53,0x59,0x05,0x0a,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Custom Mode Query"
    icon: mdi:cog
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0x3B + (int)x;
                    return {0x53,0x59,0x05,0x89,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Motion trigger time"
    icon: mdi:camera-timer
    unit_of_measurement: "ms"
    min_value: 0
    max_value: 4294967295
    step: 5000
    set_action:
                    int crc = 0xC4 + (int)x;
                    int h24_num = ((int)x >> 24) & 0xff;
                    int h16_num = ((int)x >> 16) & 0xff;
                    int h8_num = ((int)x >> 8) & 0xff;
                    int l8_num = (int)x & 0xff;
                    return {0x53,0x59,0x08,0x0c,0x00,0x04,(uint8_t)h24_num,(uint8_t)h16_num,(uint8_t)h8_num,(uint8_t)l8_num,(uint8_t)crc,0x54,0x43};
    name: "Custom Movement to rest time"
    min_value: 0
    step: 5000
    set_action:
                    int crc = 0xC5 + (int)x;
                    return {0x53,0x59,0x08,0x0d,0x00,0x04,(uint8_t)h24_num,(uint8_t)h16_num,(uint8_t)h8_num,(uint8_t)l8_num,(uint8_t)crc,0x54,0x43};
    name: "Custom Time of entering unmanned state"
    min_value: 0
    step: 5000
    set_action:
                    int crc = 0xC6 + (int)x;
                    return {0x53,0x59,0x08,0x0e,0x00,0x04,(uint8_t)h24_num,(uint8_t)h16_num,(uint8_t)h8_num,(uint8_t)l8_num,(uint8_t)crc,0x54,0x43};
text_sensor:
- platform: custom
  lambda: |-
    auto my_custom_sensor = new MyCustomTextSensor();
    App.register_component(my_custom_sensor);
    return {my_custom_sensor->Heartbeat};
  text_sensors:
    - name: "Standard Heartbeat"
      icon: mdi:connection
  name: "Standard Product model"
  icon: mdi:information-outline
  on_raw_value:
    then:
      - logger.log: text_sensor on_raw_value
  name: "Standard Product ID"
  name: "Standard Hardware model"
  name: "Standard Firmware version"
  name: "Standard protocol type"
  name: "Standard moving direction"
  icon: mdi:walk
  name: "Standard Sports information"
  icon: mdi:human-greeting
  name: "Standard Presence information"
  icon: "mdi:motion-sensor"
  name: "Custom Presence of detection"
  icon: mdi:signal-distance-variant
# - platform: template
#   name: "Custom Motion distance"
#   id: custom_motion_distance
#   name: "Custom Static distance"
#   id: custom_static_distance
#   name: "Custom Spatial static value"
#   id: custom_spatial_static_value
#   name: "Custom Spatial motion value"
#   id: custom_spatial_motion_value
#   name: "Custom Motion speed"
#   id: custom_motion_speed
button:
    icon: mdi:reload
    on_press:
      then:
        - logger.log: Button Pressed
        - uart.write: [0x53,0x59,0x01,0x02,0x00,0x01,0x0F,0xBF,0x54,0x43]
switch:
    name: "Custom Infor output switch"
    icon: mdi:electric-switch
    assumed_state: true
    turn_on_action:
      - uart.write: [0x53,0x59,0x08,0x00,0x00,0x01,0x01,0xB6,0x54,0x43]
      - delay: 1s
      - lambda: !lambda |-
          id(product_mode).publish_state("");
          id(product_id).publish_state("");
          id(hardware_model).publish_state("");
          id(firmware_version).publish_state("");
          id(protocol_type).publish_state("");
    turn_off_action:
      - uart.write: [0x53,0x59,0x08,0x00,0x00,0x01,0x00,0xB5,0x54,0x43]
- platform: custom
  lambda: |-
    auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
    return {
      my_custom_sensor->movementSigns,
      my_custom_sensor->inited,
  sensors:
    - name: "Standard body movement"
      icon: "mdi:human-greeting-variant"
      device_class: "temperature"
      state_class: "measurement"
    - name: "Standard inited"
      icon: mdi:all-inclusive
  on_value:
    then:
      # - logger.log: Custom Motion distance on_value
      - logger.log:
            format: "Custom Motion distance on_value : %d"
            args: ["x"]
  on_raw_value:
    then:
      - logger.log:
            format: "Custom Motion distance on_raw_value : %d"
            args: ["x"]
  icon: mdi:counter
  icon: mdi:counter
  icon: mdi:run-fast
