Mobile App component error
Hoping this is something silly and simple to fix.
Was using the beta iOS app with the mobile_app component in my configuration.yaml.
mobile_app:
All was working well.
Had a power cut the other day and after it all came back had the following error in the notifications:
The following components and platforms could not be set up:
* [mobile-app]
Please check your config.
Thing tried:
  • Removing intergration from UI
  • Reinstalling Beta App
  • Removing and then re-adding mobile_app:
No the beta app kind find any instances of HA on my network…
Any ideas that i can try?
–EDIT–
Also - running Hass.io on a VM - 0.99.2
You could try the scorched earth approach:
https://companion.home-assistant.io/en/next/troubleshooting/beta-cleaning
That did it! Thank’s so much!
