Mobile App Sensor Update iOS
Hi there.
I have following problem.
Two iPhones:
iPhone XS Max
iPhone 16pro Max
Both with HA mobile App Version 2024.9.4 and iOS 18.0
XS Max:
If i Plug in the charging cable, the status change from “not charging“ to “charging“. It‘s not important if the App is in forgeground or not.
16pro Max:
only updates the stats if the App is in forgeground.
The Setting on Both devices are the same.
Someone any idea to fix this Problem?
I Need the charging status for some automations in the evening.
Did you find a solution?
