**Home Assistant Android app version(s):**
2024.4.1-full
**Android version(s…):**
14
**Device model(s):**
Google Pixel 6 Pro
**Home Assistant version:**
2024.5.1
**Last working Home Assistant release (if known):**
**Description of problem, include YAML if issue is related to notifications:**
Hello, I'm facing an issue with the TTS notifications in the mobile app (latest version, but it was the case with previous versions too) when sending multiple TTS notifications to the same device either in a single automation or from multiple automations running in parallel.
I would expect HA to queue the notifications sent to the app, so they are all played in the order of appearance in the list, but it doesn't. It looks like if a notification is sent while there is an ongoing notification text spoken, the new one is ignored.
Example automation:
```yaml
alias: Test multiple TTS
description: ""
trigger: []
condition: []
- service: notify.mobile_app_pixel_6_pro
message: TTS
priority: high
ttl: 0
tts_text: 1, 2, 3, 4, 5, 6, 7, 8
enabled: true
message: TTS
priority: high
ttl: 0
tts_text: 9, 10
enabled: true
mode: single
The second ”9, 10" text is ignored. I would expect it to be queued and played after the "8".
How to ensure no notification is lost ?
**Companion App Logs:**
--------- beginning of main
05-06 23:35:10.642 24168 24168 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1715031222110, currentMillis: 1715031310642)
05-06 23:35:10.660 24168 24168 D VRI[SettingsActivity]: Start draw after previous draw not visible
05-06 23:35:10.664 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:10.665 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:10.691 24168 24168 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1715031222110, currentMillis: 1715031310691)
05-06 23:35:10.691 24168 24168 D IntegrationRepository: setAppActive(): true
05-06 23:35:12.873 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:12.983 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:13.140 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:13.269 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:13.432 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:13.518 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:14.416 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:14.534 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:14.942 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:15.026 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:15.626 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:15.718 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:16.285 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:16.344 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:16.411 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:16.837 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:16.902 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:17.026 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:17.321 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:17.471 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:17.721 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:17.812 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:17.938 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:18.037 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:18.122 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:18.412 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:18.453 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:18.487 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:18.529 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:18.587 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:18.648 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.364 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.390 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.414 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.448 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.464 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.480 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.498 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.513 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.530 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.556 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.573 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.613 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.632 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.655 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.673 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.706 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.724 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.755 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.773 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.797 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.823 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.855 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.881 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:20.906 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:21.415 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:21.891 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:22.024 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:22.131 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:22.291 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:22.701 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:23.538 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:26.605 24168 10140 D LogcatReader: Read logcat for pid 24168
05-06 23:35:26.667 24168 10140 D LogcatReader: Done reading logcat for pid 24168
05-06 23:35:29.640 24168 24168 D LocBroadcastReceiver: Received location update.
05-06 23:35:29.646 24168 24168 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
05-06 23:35:29.646 24168 10140 D LocBroadcastReceiver: Last Location:
05-06 23:35:29.646 24168 10140 D LocBroadcastReceiver: Coords:(45.3266959, 5.5503222)
05-06 23:35:29.646 24168 10140 D LocBroadcastReceiver: Accuracy: 100.0
05-06 23:35:29.646 24168 10140 D LocBroadcastReceiver: Bearing: 0.0
05-06 23:35:29.646 24168 10140 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
05-06 23:35:29.647 24168 10140 D LocBroadcastReceiver: Received location that is 39 milliseconds old, 1715031329607 compared to 1715031329646 with source fused
05-06 23:35:29.647 24168 10140 D LocBroadcastReceiver: Duplicate location received, not sending to HA
05-06 23:35:47.816 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:47.817 24168 24168 I ImeTracker: io.homeassistant.companion.android:88ceda40: onRequestHide at ORIGIN_CLIENT_HIDE_SOFT_INPUT reason HIDE_SOFT_INPUT_CLOSE_CURRENT_SESSION
05-06 23:35:54.225 24168 24168 W WindowOnBackDispatcher: sendCancelIfRunning: isInProgress=falsecallback=androidx.activity.OnBackPressedDispatcher$Api34Impl$createOnBackAnimationCallback$1@d7c3539
05-06 23:35:54.250 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:54.251 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:35:58.821 24168 24168 D IntegrationRepository: setAppActive(): false
05-06 23:35:59.195 24168 24168 D VRI[SettingsActivity]: visibilityChanged oldVisibility=true newVisibility=false
05-06 23:35:59.214 24168 24168 D VRI[SettingsActivity]: Not drawing due to not visible
05-06 23:36:29.675 24168 24168 D LocBroadcastReceiver: Received location update.
05-06 23:36:29.679 24168 24168 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
05-06 23:36:29.679 24168 10140 D LocBroadcastReceiver: Last Location:
05-06 23:36:29.679 24168 10140 D LocBroadcastReceiver: Coords:(45.3266959, 5.5503222)
05-06 23:36:29.679 24168 10140 D LocBroadcastReceiver: Accuracy: 100.0
05-06 23:36:29.679 24168 10140 D LocBroadcastReceiver: Bearing: 0.0
05-06 23:36:29.680 24168 10140 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
05-06 23:36:29.680 24168 10140 D LocBroadcastReceiver: Received location that is 71 milliseconds old, 1715031389609 compared to 1715031389680 with source fused
05-06 23:36:29.680 24168 10140 D LocBroadcastReceiver: Duplicate location received, not sending to HA
05-06 23:36:43.887 24168 24168 D SensorReceiver: Received intent: android.media.VOLUME_CHANGED_ACTION
05-06 23:36:43.890 24168 24168 D SensorReceiver: Sensor(s) [volume_accessibility, volume_alarm, volume_call, volume_dtmf, volume_notification, volume_music, volume_ring, volume_system] corresponding to received event android.media.VOLUME_CHANGED_ACTION are disabled, skipping sensors update
05-06 23:36:45.960 24168 24168 D SensorReceiver: Received intent: android.media.VOLUME_CHANGED_ACTION
05-06 23:36:45.962 24168 24168 D SensorReceiver: Sensor(s) [volume_accessibility, volume_alarm, volume_call, volume_dtmf, volume_notification, volume_music, volume_ring, volume_system] corresponding to received event android.media.VOLUME_CHANGED_ACTION are disabled, skipping sensors update
05-06 23:36:46.910 24168 24168 D SensorReceiver: Received intent: android.media.VOLUME_CHANGED_ACTION
05-06 23:36:46.912 24168 24168 D SensorReceiver: Sensor(s) [volume_accessibility, volume_alarm, volume_call, volume_dtmf, volume_notification, volume_music, volume_ring, volume_system] corresponding to received event android.media.VOLUME_CHANGED_ACTION are disabled, skipping sensors update
05-06 23:36:47.481 24168 24168 D SensorReceiver: Received intent: android.media.VOLUME_CHANGED_ACTION
05-06 23:36:47.483 24168 24168 D SensorReceiver: Sensor(s) [volume_accessibility, volume_alarm, volume_call, volume_dtmf, volume_notification, volume_music, volume_ring, volume_system] corresponding to received event android.media.VOLUME_CHANGED_ACTION are disabled, skipping sensors update
05-06 23:37:04.700 24168 19607 W FirebaseMessaging: Unable to log event: analytics library is missing
05-06 23:37:04.700 24168 19607 D FCMService: From: 331041709873
05-06 23:37:04.703 24168 24168 D TextToSpeech: Sending text to TTS
05-06 23:37:04.718 24168 24168 I TextToSpeech: Sucessfully bound to com.google.android.tts
05-06 23:37:04.720 24168 31605 I TextToSpeech: Connected to TTS engine
05-06 23:37:04.752 24168 25859 I TextToSpeech: Setting up the connection to TTS engine...
05-06 23:37:04.754 24168 24168 D TextToSpeech: speaking text
05-06 23:37:04.903 24168 19607 W FirebaseMessaging: Unable to log event: analytics library is missing
05-06 23:37:04.903 24168 19607 D FCMService: From: 331041709873
05-06 23:37:04.904 24168 24168 D TextToSpeech: Sending text to TTS
05-06 23:37:04.908 24168 24168 I TextToSpeech: Sucessfully bound to com.google.android.tts
05-06 23:37:04.913 24168 17583 I TextToSpeech: Connected to TTS engine
05-06 23:37:04.915 24168 25859 I TextToSpeech: Setting up the connection to TTS engine...
05-06 23:37:04.917 24168 24168 D TextToSpeech: speaking text
05-06 23:37:08.130 24168 6986 I TextToSpeech: Disconnected from TTS engine
05-06 23:37:12.166 24168 24168 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1715031359821, currentMillis: 1715031432166)
05-06 23:37:12.194 24168 24168 D VRI[SettingsActivity]: Start draw after previous draw not visible
05-06 23:37:12.205 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:37:12.233 24168 24168 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1715031359821, currentMillis: 1715031432233)
05-06 23:37:12.233 24168 24168 D IntegrationRepository: setAppActive(): true
05-06 23:37:13.449 24168 24168 W TextView: onProvideContentCaptureStructure(): calling assumeLayout()
05-06 23:37:15.146 24168 24168 W WindowOnBackDispatcher: sendCancelIfRunning: isInProgress=falsecallback=android.app.Dialog$$ExternalSyntheticLambda2@a896525
05-06 23:37:15.199 24168 26284 D HWUI : endAllActiveAnimators on 0xb400007842a5cc10 (RippleDrawable) with handle 0xb4000077528ab2d0
05-06 23:37:15.227 24168 24168 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: true, expireMillis: 1715031359821, currentMillis: 1715031435227)
05-06 23:37:15.227 24168 24168 D IntegrationRepository: setAppActive(): true
05-06 23:37:16.378 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:37:16.379 24168 24168 E mpanion.android: Invalid resource ID 0x00000000.
05-06 23:37:17.676 24168 10140 D LogcatReader: Read logcat for pid 24168
05-06 23:37:17.728 24168 10140 D LogcatReader: Done reading logcat for pid 24168
05-06 23:37:18.654 24168 10140 D LogcatReader: Read logcat for pid 24168
**Screenshot or video of problem:**
**Additional information:**
Discussed here also:
https://community.home-assistant.io/t/mobile-app-tts-notification-queueing/726312/1
