đŸ“± Mobile First Dashboard - A minimalist and user-friendly UI for your dashboard
Hello. Nice work.
Can you share your automation.volets_fermeture_si_il_fait_ensoleille and your input_select.type_de_contenu. Please
Also on your search part, how do you have a youtube musique search browse feature
thanks for your help
Hi!
This is a beautiful layout. Great, great work!
Might you know why when I attempt to navigate to the dashboard, I get a white screen? The only way I can get the dashboard to load is if I enter raw configuration editor and then exit. Then everything loads.
Thanks for any help!
So - I’ve followed the instructions, but for some reason, I have absolutely nothing appear in my dashboard
 F12 gives me no relevant errors!
Halp!
Hi!
I’m having the same issue. Were you able to find the cause for this?
Regards
Hi, sorry for the late reply. Everything is still working for me even after the new 2023.7 update. Without more information I’m not sure how I can help you, but I’m working on an all-new version that will be a lot easier to install. I’m focusing a lot on this point.
You can find all the updated information here:
Hey @Cloos, first! amazing dashboard, waiting for your implementation to Tablet!
Second, i stuck on step 10-11 trying to config it.
i need to create a new view (etc Footer\Header) choose Thene:noctis, view type: Sidebar, then in this view to enter Raw configuration editor, and right after
cards: i need to past from Lovelace file from ''decluttering_templates (include) until title (not include), to do changed depand to my names.
and than what? i create new view (Home for example) with Theme:noctis, view type (Masinry) and toggle subview?
because if yes, i add cards just to try and i dont see any header and footer.
what i missed?
Installing the theme on 2023.07.01 is currently not working
Hi, have you followed these points?
In the folder you downloaded earlier, open the lovelace.yaml file with a text editor.
Copy all the lines of code from decluttering_templates: to the last line right before title:.
Paste this code in the top of your Raw configuration editor in Home Assistant.
Hi, can you tell me what is not working? The theme is still working for me on 2023.07 but it was installed way before this version.
Hi!
Thank you for your reply.
After I followed the steps from github, the only thing I see on my dashboard is:
I have the same problem. If i edited in the config edit and save it will show me the cards.
Hey there
 Great dashboard!! I’m in the process of trying to set it up
 Can you tell me what this code is doing for you? I just have a bunch of Alexa’s around the house
 Curious what your “media_player” is and what that Deezer switch is doing
 Thanks!!
- type: custom:vertical-stack-in-card
                    cards:
                      - type: conditional
                        conditions:
                          - entity: media_player.musique
                            state: 'off'
                        card:
                          type: custom:paper-buttons-row
                          buttons:
                            - entity: switch.deezer
                              icon: mdi:music
                              layout: icon_name
                              state_styles:
                                'off':
                                  button:
                                    position: absolute;
                                    top: 50%;
                                    border-radius: 100%;
                                    width: 42px
                                    height: 42px
                                    margin-top: '-46px'
                                    filter: drop-shadow(0px 2px 2px rgba(0,0,0,0.2))
                                    background: >-
                                      var( --ha-card-background,
                                      var(--card-background-color, white) );
                                    background-size: 140% 70%
                                    background-repeat: no-repeat
                                    background-position: 50% 100%
                                    background-color: '#3e4c69'
                                  icon:
                                    margin-top: 44px
                                  name:
                                    margin-top: 20px
                                    width: 100px
                                'on':
                                  button:
                                    display: none;
                      - type: conditional
                        conditions:
                            state_not: 'off'
                        card:
                          type: custom:mini-media-player
                          volume_stateless: true
                          group: false
                          volume_step: '3'
                          sound_mode: full
                          artwork: full-cover
                          toggle_power: false
                          source: icon
                          hide:
                            source: true
                          style: >
                            ha-card {
                              height: 100% !important;
                              width: 100% !important;
                              position: absolute !important;
                            }   .flex {
                              display: block;
                              {% if not is_state('media_player.musique','off') %}
                              filter: drop-shadow(0px 2px 2px rgba(0,0,0,1));
                              {% else %}
                              {% endif %}
                            }   ha-card.--has-artwork .cover{
                              opacity: 0.9;
                            }  .entity__info__media {
                              opacity: 1 !important;
                              padding-right: 16px;
                              overflow: hidden;
                              height: 4.4em;
                              height: 100%;
                            }  div.entity__icon {
                              display: none;
                              {% endif %}
                            }   mmp-media-controls {
                              flex-wrap: wrap-reverse !important;
                              {% endif %}
                            } ha-card > div.mmp-player {
                              padding: 12px !important;
                              {% else %}
                              #display: none !important;
                              {% endif %}
                              {% if is_state_attr('media_player.salon','media_content_id', 'Bluetooth') %}
                              position: relative;
                              height: 20vh;
                              {% else %}
                              position: absolute;
                              align-self: flex-start;
                              height: 100%;
                              {% endif %}
                              background: radial-gradient(circle, rgba(0,0,0,0) 10%, rgba(0,0,0,0.6) 100%) !important;
                              font-size: 0.9em !important;
                            }   ha-card > div.mmp-player > div.mmp-player__adds
                              position: absolute;
                              bottom: 14px;
                              padding: 0 16px 0 0;
                            }   div.flex.mmp-media-controls__media {
                              margin-bottom: -5px !important;
                    style: |
                      ha-card {
        style: |
          ha-card {
            margin: 14px 20px !important;
            background: none;
          .type-custom-vertical-stack-in-card {
            overflow: visible !important;
@Joeri94 @leecable34 @robnnson
I think i have found the reason why. Try removing the following section in in yaml code in the dashboard view:
visible:
- user: a27a825440914ad7a919367c2e53793e
- user: aadd52d881af46bca495e279bee867bf
- user: 10a78a75e63f4c5ba22a81742f59b925
Hi, this is a switch that start my “Flow” on Deezer, it replace the player when there is no media playing.
Thank you for your comment Nico!
I reviewed the stapes I took and found something I did wrong. Initial dashboard shows now!
Thanks for the reply. So are you just sending it to a Sonos or something? Is that what media_player.musique is?
Another question
 How are you getting the presence stuff for the last 24 hours and the info from this sensor: sensor.geraldine_temps_a_domicile
>    - entity: sensor.geraldine_temps_d_absence
>             type: custom:multiple-entity-row
>             state_header: Absente
>             secondary_info: DerniĂšres 24h
>             entities:
>               - entity: sensor.geraldine_temps_a_domicile
>           - type: section
>           - entity: sensor.iphone_de_geraldine_battery_level
>             name: État du tĂ©lĂ©phone
>             state_header: Batterie
>             entities:
>               - entity: sensor.iphone_de_geraldine_activity
>           - type: section
>           - entity: sensor.iphone_de_geraldine_geocoded_location
>             styles:
>               text-align: right
>           - type: section
>             cards:
>               - type: history-graph
>                 entities:
>                   - entity: sensor.geraldine_presence
>                     title: GĂ©raldine
>                 hours_to_show: 24
>                 refresh_interval: 0
>                 style: |
>                   ha-card {
>                     margin: -10px -10px 6px;
>               - type: map
>                 entities:
>                   - entity: person.geraldine2
>                 dark_mode: false
>                 style: |
>                   ha-card {
>                     border-radius: 28px !important;
You’re welcome! Yes, this is a Denon AVR, the switch turn on a script that start the music. And for your second question here is what I use:
Really like the header with weather and trying to apply it in my own dashboard. I tried style ha-card and card mod but I can’t get background:radial-gradient and keyframes opacity working.
I now have the code below and would go from there, I don’t need ready-made code but anyone have an idea which direction I should look?
- type: conditional
            conditions:
              - entity: sun.sun
                state: above_horizon
            elements:
              - type: image
                image: /local/weather/day.png
                tap_action:
                  action: none
                style:
                  left: 50%
                  top: -35%
                  Width: 100%
                  opacity: 85%
                  transform: scale(2.0,0.2)
This is an amazing dashboard! Thank you for the hard work. Trying to adapt it for myself now.
I love the header showing live weather condition, but I do not have a camera pointing outside. Does anyone have a list of images I can use for different weather conditions to put in the top banner?
Also for the footer is there a way to make it show only when scrolling down so it’s not always visible?
