Modbus between Shelly 3EM and Sungrow Inverter
Summary: How can I set up modbus gateway with esphome between inverter and Shelly 3EM?
I can read data from Sungrow inverter with modbus tcp. Thanks to GitHub - MatterVN/ModbusTCP2MQTT: Sungrow & SMA Solar Inverter addon for Home Assistant using mobusTCP. I can get all values of 3 phases with Shelly 3EM. Unfortunately I don’t have a limiter. Shelly 3EM does not have modbus either. Can I send the power values that read from Shelly 3EM to the inverter with the help of an esp32? I have TTL-RS485 component for esp32 and modbus.
With default esphome: no.
You need write the code to emulate a modbus slave.
In theory it seems possible, right? Now I should find registers and data types to emulated it.
Did you find a solution? I got the same problem but I have no idea how to do it.
I just have seen your topic.
There is a new Shelly Pro 3EM with Modbus
https://www.shelly.cloud/en-de/products/product-overview/pro-3-em
did you find a solution ? it’s actual for now …
You need clone a compatible device, and emulate it as slave
pymodbus slave
Any success on project?
