I’m trying to create a cover. The cover works, I can write a value between 0 and 100 and the cover does as expected. But I cannot get the Sensor to grab the current value.
I’ve tried a lot of different combinations with no luck. The sensor reports 0 or 1, 0 if not running, 1 if the blinds are moving.
When I look at the system, I can see the current setting. Any ideas what I do wrong
My Code is as follows for the sensor tried 3 different ways to do it :
- name: "sh_gardin_movement_position"
input_type: holding
slave: 1
address: 1832
scan_interval: 1
- name: "sh_gardin_movement_position2"
slave: 1
address: 1832
scan_interval: 1
- name: "sh_gardin_movement_position3"
slave: 1
address: 1832
scan_interval: 1
status_register_type: holding
