Anyone else getting annoyed with all these modbus changes being made? Is there actually a thread that can moderate what is being changed/developed or proposed
According to Modbus - Home Assistant there are 508 active MODBUS deployments but am sure there are more that do not have component reporting turned on
RANT
So far the following has broken my running config
Sensors moved under individule HUB
Multiple HUB / sensors not working
Now its “structure” being removed
Just stop and ask the community what they are using, and why
RANT over
Well, I am glad someone is actively working on the Modbus integration. I am sure there were good reasons for changes in config syntax.
And multiple hub / sensor issues are resolved now.
Yep, not saying its a bad thing, just that the changes are being made without thought for the use other people that use it for
As an example, I use two modbus inverters but seems having multiple devices/hubs was not even a thought for the change that was implemented and broke a lot of configs
Thanks, Will keep an eye on it for future reference as 3 changes so far have broken my config and the “Partner Approval Factor” has taken a knock
Cheers
Not sure I fully understand what you mean, I can only say that I have 2 hubs as well and there was a bug that prevented the second hub from operating properly - this was fixed here.
The developers are not able to test every possible config, so before upgrading, one should always have a clear route to roll back to the previous working version.
If something breaks, I do roll back, and when I have time, rtfm, check the bug reports, and report a problem if needed.
