Hi!
Using modbus to control hvac/ventilation at home. After a update, actual temperature on climate card is really wrong. My supply air settings i set to 23 degrees, but actual supply air is showing 201 degrees. But the right temperature should be 20,1 degrees. Tried to edit scale, but then the settings temperature got wrong. Anyone who could help me? added 1 pictures showing ![spm 2|496x328]
climate card
climates:
- name: Ventilasjon_klima
slave: 1
data_type: int16
count: 1
scale: 1
offset: 0
precision: 1
max_temp: 26
min_temp: 15
temp_step: 1
input_type: input
target_temp_register: 1
address: 2
