So I have 2 working modbus servers I’m polling with several sensor and switch entities.
I’m trying to add a climate entity to one but when adding:
climates:
- name: Thermia_Heat_Clim
target_temp_register: 5
Check configuration is just an infinite load, restarting homeassistant gives an error just saying ‘address’
In the logs I can’t find anything meaningful, any tips?
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:226
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 17:21:59 (1 occurrences)
Last logged: 17:21:59
[139857353638464] 'address'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 226, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2012, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2049, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 986, in admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 168, in async_handle_core_service
errors = await conf_util.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 973, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 180, in async_check_ha_config_file
config = config_schema(config)
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 387, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.11/site-packages/voluptuous/validators.py", line 229, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.11/site-packages/voluptuous/validators.py", line 353, in _exec
v = func(path, v)
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/modbus/validators.py", line 242, in duplicate_entity_validator
addr = str(entry[CONF_ADDRESS])
KeyError: 'address'
